DUNU VULKAN 2 In-Ear Monitors
New
The Dunu Vulkan 2 is a pair of new-generation hybrid in-ear headphones, designed to deliver wideband sound reproduction using a highly segmented acoustic architecture. Each earphone incorporates eight transducers per side (2 dynamic + 6 balanced armature), relying on four-way frequency management to cover the entire audible spectrum with clear functional distribution. This design aims for structured and consistent reproduction, where each register has its own mode of operation without compromising interaction.
By buying this product you get 38 loyalty points
Reference : 21508
389,00 €tax incl.
324,17 € tax excl.
Dunu Vulkan 2 In-Ear Monitors IEM Dynamic Balanced Armature 35 Ohm 128dB 5Hz-40kHz
Dunu Vulkan 2 : Front view
The Dunu Vulkan 2 is a pair of new-generation hybrid in-ear monitors, designed to deliver wideband sound reproduction using a highly segmented acoustic architecture. Each earphone incorporates eight transducers per side (2 dynamic + 6 balanced armature), relying on four-way frequency management to cover the entire audible spectrum with clear functional distribution. This design aims for structured and consistent reproduction, where each register has its own mode of operation without compromising interaction.
In addition to this multi-transducer architecture, the Vulkan 2 employs a dual physical and electronic filtering system, enabling precise separation of frequency bands while ensuring smooth transitions between registers. This approach allows for a clearer reading of complex signals, while maintaining the tonal continuity essential for high-quality listening.
Dunu Vulkan 2: Hybrid architecture
The acoustic heart of the Vulkan 2 is based on an advanced hybrid configuration, in which the bass registers are handled by two independent dynamic drivers. A 10 mm transducer dedicated to sub-bass frequencies and a second 8 mm transducer dedicated to bass frequencies operate in physically separate acoustic chambers, eliminating the mechanical interference phenomena typical of coaxial architectures. This structural separation allows for more controlled frequency response, while preserving the impact and clarity of the lower midrange.
Dunu Vulkan 2 : Frequency response curve
This dynamic foundation is extended by a midrange section provided by two customised Knowles balanced armature drivers, calibrated to reproduce vocals and instruments with precise articulation and stable texture. For high frequencies, four dedicated balanced armature drivers take over, ensuring a smooth extension into the treble and ultra-treble ranges, while maintaining a consistent level of detail without artificial accentuation.
Dunu Vulkan 2: Four-way crossover
Signal management is based on a four-way crossover combining independent acoustic channels and precision electronic filtering. Each register has its own propagation path, allowing complete functional decoupling of the transducers. This arrangement improves the clarity of the sound message, while ensuring overall consistency between the different bands.
This approach ensures a balanced frequency response, where the density of the bass does not mask the midrange, while the treble retains its definition without harshness. The result is a consistent sound reproduction, capable of adapting to a variety of musical styles, fr om acoustic ensembles to more complex productions.
Dunu Vulkan 2 : crossover
Dunu Vulkan 2: Bass reproduction
Thanks to its two isolated dynamic drivers, the Vulkan 2 delivers deep, structured bass. The sub-bass frequencies are extended significantly, while the low-mid frequencies retain their clear, rapid impact. This configuration allows for precise reproduction of bass lines and percussion, while providing a stable foundation for the rest of the spectrum.
Dunu Vulkan 2 : Speakers
This mastery of the lower end of the spectrum results in a broader soundstage and better separation between layers, enhancing the perception of depth without weighing down the overall sound.
Dunu Vulkan 2: Aluminium shells
The Vulkan 2's shells are CNC-machined from aerospace-grade aluminium alloy, ensuring both structural rigidity and control of unwanted resonance. This mechanical design contributes to the acoustic stability of the internal chambers, while ensuring durability suitable for regular mobile use.
The metallic finish, with its sober and uniform colours, is part of a functional approach where aesthetics derive directly from mechanical and acoustic constraints rather than decorative treatment.
Dunu Vulkan 2: Silver-plated copper cable
The Vulkan 2 comes with a premium four-conductor cable made of high-purity silver-plated monocrystalline copper, assembled in a Litz configuration to preserve signal integrity throughout its length. This connection promotes stable transmission, limiting losses and impedance variations.
This cable incorporates the patented Q-Lock Mini system, allowing interchangeable use of the original 3.5mm unbalanced and 4.4mm balanced connectors.
Dunu Vulkan 2 : 3.5mm and 4.4mm jack termination
Product typeIn-ear earphones
Drivers2x Dynamic driver
6x Balanced armature driver
Frequency response5Hz-40kHz
Impedance35Ω
Sensitivity113dB/mW @ 1kHz
128dB/Vrms @ 1kHz
Total harmonic distortion (THD)< 0.3%
Earphone connectorsMMCX
Cable terminationJack 3.5mm
Jack 4.4mm
Cable length1.2m
ColorChampagne
Package1x Dunu Vulkan 2
1x Earphone cable
1x 3.5mm jack termination
1x 4.4mm jack termination
1x Carrying case
1x 3.5mm to 6.35mm jack adapter
12x Pairs of ear tips
ColorChampagne
Impedance (Ω)35
Efficiency / Sensitivity (dB)128.0
WirelessNo
Cable terminationJack 4.4mm
Headphone / Earphone connectorMMCX
Phone call featureNo
Noise reductionNo
Vindiouse
Cet intra auriculaire est terrible, son grave est abyssale une fois qu'on a trouvé les bons embouts, j'ai rarement entendu un intra descendre de cette manière et aussi propre et texturé. Le médium a également quelque chose d'envoutant, il est également très texturé sur l'album de Aleksi Perälä - The colundi séquence en 24/192 nativement les basses sont terriblement abyssale profonde et terriblement belle. L'aigu lui va loin sans agressivité et pas du tout fatiguant sur de longues heures. Je ne connaissais absolument pas cette marque mais là je crois que je suis dinguement amoureux. Certe il a pas un punch comme certains intra auriculaire auront mais c'est le côté sublime du grave et de l'infra grave qui donne à la musique tout son sens et son médium vient rehaussé ça avec un croustillant terriblement beau et sans agressivité. Pour ma part j'utilise un Fiio M21 et l'application Qobuz pour son excellente qualité de fichiers audio.
Les accessoires sont de très bonnes factures, j'ai été bluffé par autant d'oreillettes de toute sorte ainsi que la qualité de l'étui de l'intra auriculaire.
Je le répète encore je suis bluffée par la qualité de la partie sub basse qui descend allègrement sous les 20 Hz avec une qualité de texture que j'ai rarement entendu. Je recommande vivement ce Dunu Vulcan 2.
This review has been posted for DUNU VULKAN 2 In-Ear Monitors IEM Dynamic Balanced Armature 35 Ohm 128dB 5Hz-40kHz
The Dunu Vulkan 2 is a pair of new-generation hybrid in-ear headphones, designed to deliver wideband sound reproduction using a highly segmented...
