By buying this product you get 26 loyalty points
With the TWS800, HIFIMAN offers Bluetooth 5.0-standard wireless in-ear monitors. They benefit from all HIFIMAN's expertise in earphone design, and incorporate an amplification stage as well as the brand's characteristic topological diaphragms, ensuring quality sound reproduction.
Being wireless earphones, the TWS800 cannot benefit from external pre-amplification. HIFIMAN solves this problem by integrating an amplification stage directly into the earphones, ensuring high-quality amplification, even with wireless earphones.
The driver structure of the TWS800 includes a 150Ω high-impedance voice coil ensuring excellent clarity across the entire frequency band. This voice coil is combined with a topological diaphragm, providing detailed, natural high-frequency reproduction.
The topological diaphragm refers to a diaphragm whose surface is coated with a special nanoparticle-based coating. The result is a more natural and detailed sound than that generally obtained with wireless earphones. The idea behind the new topological membrane was inspired by Dr Fang Bian's doctoral thesis, which states that ‘different nanomaterials have different structures and each of these materials has its own properties’. Therefore, by carefully controlling the surface structure of the diaphragm, we can achieve different results that are superior in terms of acoustic performance to a degree previously unattainable.
In terms of battery life, the TWS 800boasts 4.5 hours of uninterrupted listening, rising to 31.5 hours when combined with the supplied charging case.
For added convenience, music playback can be controlled with a simple touch of the headphones. A single touch controls song playback. A double press on the side controls volume: right to increase, left to decrease. A triple press on the side controls track scrolling: right to skip to the next track, left to go back. Finally, a 2-second long press activates the voice assistant.
Product type | Wireless In-Ear Monitor IEM |
Frequency response | 20Hz-20kHz |
Bluetooth version | 5.0 |
Supported Bluetooth codecs | AAC, SBC |
Noise reduction | 23dB |
Protection class | IPX4 |
Bluetooth operating distance | 15m (barrier-free open environment) |
Autonomy | |
Battery life of earphone | 4.5h |
Earphone recharge time | 1h |
Battery life of charging case | 27h |
Case recharge time | 2h |
Weight | Earphone : 6.9g Case : 74.4g |
Color | Silver |
Package | 1x HIFIMAN TWS800 1x Charging case 1x USB-A to USB-C cable 9x Pairs of earphone tips |
Color | Silver |
Impedance (Ω) | NC |
Efficiency / Sensitivity (dB) | N/A |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 20000 |
Wireless | Yes |
Cable termination | NC |
Headphone / Earphone connector | NC |
Phone call feature | No |
Noise reduction | No |
