By buying this product you get 20 loyalty points
In-Ear Monitor Dynamic Driver Nanotube Diaphragm Ø10mm 16 Ohm Gray
iBasso reinvents its range of mid-range in-ear headphones with the IT01s, specially designed for audiophiles looking for exceptional playback. Using an assembly of high-end technologies, iBasso innovates and marks a turning point in their proposal for headphones with dynamic loudspeakers.
The iBasso IT01S are the first IEMs to use Tesla magnetic flux, membranes with carbon nanotubes and DLC plating together. This is the latest technology for dynamic loudspeakers. This architecture, iBasso calls it DiNaTT™.
3.8µm Carbon Nanotube dome diaphragm
DLC coating on the dome diaphragm
High Tesla Magnetic Flux
The DiNaTT™ technology offers the thinnest carbon nanotube dome membrane with only 3.8µm. This extreme thinness makes these membranes extremely easy to move. The membrane also uses the advances associated with the use of carbon nanotubes and DLC plating on the dome. Nanotubes provide greater membrane stiffness to extend the frequency response range and improve dynamic response. The DLC plating of the dome provides a better transient response, greater stability and more accurate highs.
The use of Tesla magnetic flux allows the 3.8µm thick membrane to be moved with great ease. This contributes greatly to improving the definition of bass and dynamics.
The IT01s benefit from a global design of very high quality, leaving no room for chance, in order to ensure the most transparent and rich sound reproduction possible. The shape of the IEMs has been designed to fit all ears, for optimal comfort and support.
The IT01s are delivered with a 5N single crystal copper cable with silver shielding. This is a symmetrical MMCX cable with 2.5mm connectors. A 2.5mm TRRS to 3.5mm TRS adapter is also provided.
| Specifications | ||
| Product type | In-Ear Monitor (IEM) | |
| Frequency response | 10Hz - 43kHz | |
| Impedance | 16Ω | |
| Noise attenuation | -26dB | |
| Power | 10mW | |
| Sensitivity | 109dB +/-2dB | |
| THD | < 1% (@ 1kHz/1mW) | |
| Connectors dimensions | 2.5mm | |
| Connectors plating | Gold | |
| Cable length | 1.2m | |
| Weight (without cable) | 8g | |
| Package | 1x iBasso IT01S In-ear monitors 1x Balanced MMCX 2.5mm cable 1x Jack 2.5mm TRRS to 3.5mm TRS adapter 1x Storage box 9x Pairs of silicone tips 2x Pairs of foam tips 2x Potection screen | |
