IBASSO KLEE In-Ear Monitor
With the Klee, iBasso is offering dynamic in-ear earphones with a stainless steel body and a magnetic-lithium alloy membrane driver, a technology usually found in much more expensive earphones.
Reference : 20521
69,00 €tax incl.
57,50 € tax excl.
iBasso KLEE Dynamic In-ear Monitor IEM Ø10mm 22Ohm 112dB 20Hz-40kHz Silver
iBasso Klee : Front view
With the KLEE, iBasso is offering dynamic in-ear earphones with a stainless steel body and a magnetic-lithium alloy membrane driver, a technology usually found in much more expensive earphones.
iBasso KLEE: Magnesium-lithium alloy diaphragm
The dynamic driver fitted to KLEE earphones has a 10mm-diameter diaphragm made from a magnesium-lithium alloy. This alloy has the dual advantage of being both extremely light and highly rigid. This enables the dynamic driver to offer a very good transient response, to provide better treble extension with greater clarity and finesse, and to reduce unwanted distortion and resonance to a minimum.
iBasso Klee : Diaphragm
iBasso Klee : Magnetic circuit
iBasso KLEE: Double magnetic circuit
To make the most of the magnesium-lithium alloy diaphragm, the KLEE incorporates a dual magnetic circuit for a total magnetic flux of 1.6T. This increased power allows for greater sensitivity, reduced distortion and improved transient response, all of which result in more accurate sound reproduction, with dynamic bass and clear midrange.
iBasso KLEE: Double Helmholtz resonance cavity
In order to refine its sound signature and control its frequency response as effectively as possible, the KLEE uses a double Helmholtz acoustic cavity to deliver furthermore punchy bass while attenuating parasitic resonances.
iBasso Klee : Cutaway view of the driver
iBasso Klee : steel housing
iBasso KLEE: Stainless steel housing
The body of the KLEE is made of stainless steel, adding a touch of luxury to a sober design featuring reflective surfaces.
iBasso KLEE: Silver-plated copper cable
The KLEE is supplied with a silver-plated copper cable. The cable has a litz wire structure and is made up of 7 conductors, each with a cross-section of 0.06mm². The cable termination is detachable and comes with 3.5mm and 4.4mm jack connectors.
iBasso Klee : Detachable cable and termination
Schéma
iBasso Klee : Diagram
1Stainless steel rear panel
2Driver support
3Magnetic circuits
4CCAW voice coil
5Magnesium-lithium alloy diaphragm
60.78mm CIEM connector
7Stainless steel housing
8Acoustic nozzle
Product typeIn-ear monitors
Driver typeDynamic
DiaphragmØ10mm in magnesium and lithium alloy
Housing materialStainless steel
Voice coilCCAW 0.03mm
Impedance22Ω
Sensitivity112dB
Frequency response20Hz-40kHz
Total harmonic distortion(THD)< 0.5%
Earphone connectorsCIEM 0.78mm
Cable terminationJack 3.5mm
Jack 4.4mm
Cable conductor materialSilver-plated copper
ColorSilver
Package1x iBasso KLEE
1x CIEM 0.78mm cable
1x 3.5mm Jack connector
1x 4.4mm Jack connector
1x Carrying pouch
9x Pairs of ear tips
ColorSilver
Impedance (Ω)22
Efficiency / Sensitivity (dB)112.0
WirelessNo
Cable terminationJack 4.4mm
Phone call featureNo
Noise reductionNo
Incroyablement bon
Ces écouteurs sont super bien réglés et délivrent un son incroyable.
Pour moins de 70 € on a absolument rien à lui reprocher.
This review has been posted for IBASSO KLEE Dynamic In Ear Monitor IEM Ø10mm 22Ohm 112dB 20Hz-40kHz Silver
With the Klee, iBasso is offering dynamic in-ear earphones with a stainless steel body and a magnetic-lithium alloy membrane driver, a technology...
