The latest advances in Moondrop product technology are at the heart of the latest addition to the Aria series! Indeed, Moondrop's Aria 2 in-ear monitors adopt the dynamic transducer and magnetic circuit design that have made the brand so successful. However, the Aria 2 not only retains the technological basis of Moondrop's flagship products, but also combines it with a newly designed brass cavity allowing, among other things, easy replacement of the ear-tips if required, and the integration of a pressure vent to boost low frequencies.
Aria 2 in-ear earphones feature an all-new composite membrane with titanium nitride coating.The two-step processing of three materials achieves a smooth treble response surpassing that of a metal-coated diaphragm, and ultra-low distortion performance that is lower than that of other crystalline-coated diaphragms. It delivers excellent treble detail and extension without any granularity or roughness.
Aria2 incorporates a new generation of replaceable acoustic filters. The front end of the brass nozzle consists of a removable tip, allowing users to replace the acoustic filter quickly and conveniently. Replacement is far easier compared with existing multi-layer filters, and the design makes for greater reliability. In the event of blockage or damage, the cost of replacement is much lower than that of standard nozzles.
Product type | In-Ear Monitors IEM |
Speaker driver type | Dynamic |
Connector | 2 pins 0.78mm |
Impedance | 33 Ohm @ 1kHz |
Sensitivity | 122dB/Vrms @ 1kHz |
Frequency response | 16Hz - 22kHz |
Total harmonic distortion (THD) | ≤ 0.05% @ 1kHz |
Couleur | Red |
Package | 1x Moondrop Aria 2 1x Earphone Cables 12x Eartips 1x Storage Case 1x User Manual |
Color | Red |
Impedance (Ω) | 33 |
Efficiency / Sensitivity (dB) | 122.0 |
Lowest frequency (Hz) | 16 |
Highest frequency (Hz) | 22000 |
Wireless | No |
Cable termination | Jack 3.5mm |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
