Moondrop unveils with the Jiu in-ear monitors benefiting from a very good quality of design and sound reproduction at an exceptionally affordable price. Each IEM embeds a 10mm diameter dynamic driver with composite membrane with Nano-Crystal coating, decentralized in an acoustically optimized cavity. These loudspeakers are powered by a motor using an N52 neodymium magnet and an ultra-thin CCAW coil, ensuring excellent performance and offering a sound reproduction that is as dynamic as it is rich in detail, while remaining faithful to the original signal. Robust, these Jiu headphones have a molded and injected metal body with the most beautiful effect. The tips allow them to eliminate unwanted resonances thanks to a particularly studied structure, significantly reducing the linear distortion of high frequencies and favoring a natural tone, while offering a very good wearing comfort, adapting perfectly to the shape of the body. 'ear. Finally, this model is equipped on its cable with a small control box incorporating a microphone, thus making it easy to answer calls.
The Moondrop Jiu have a frequency response of 10Hz -35kHz and will allow you to enjoy rich and detailed sound. We will also note their sensitivity of 110dB.
These headphones integrate a DSP chip into the USB interface to create a purer listening experience with natural sound and pleasing bass.
| Specifications | |
| Product type | In-ear monitors (IEM) |
| Speaker type | Dynamic 10mm |
| Diaphragm | Composite diaphragm, titanium coating |
| Magnet | Neodymium N52 |
| Coil | CCAW 0.035mm |
| Body material | Zinc Alloy |
| Sensitivity | 110dB/Vrms @ 1kHz |
| THD | ≤ 1% @ 1kHz |
| Frequency response | 10Hz -35kHz (IEC61094) |
| Effective frequency response | 20Hz-20kHz (IEC60318-4, -3dB) |
| Controls / Microphone | |
| Connector | USB-C |
| Color | Black |
| Impedance (Ω) | NC |
| Efficiency / Sensitivity (dB) | 110 |
| Lowest frequency (Hz) | 10 |
| Highest frequency (Hz) | 35000 |
| Wireless | No |
| Cable termination | USB-C |
| Headphone / Earphone connector | Non-detachable cable |
| Phone call feature | Yes |
