The Moondrop Pill are OWS (Open Wearable Stereo) clip-on earbuds with a futuristic design and a transparent capsule-shaped charging case. The clip-on design is ideal for comfortable wear and a secure fit, perfect for listening on the go or during a workout.
The Pill also offers excellent sound performance with a particularly efficient 13mm driver, optimized calibration, and numerous sound customization options, thanks in particular to the Moondrop Link app and built-in DSP. These earbuds also provide excellent battery life and IPX4 waterproof protection.
Moondrop Pill earphones are designed for everyday use and long listening sessions. Their shape is also perfectly compatible with wearing glasses. But in addition to offering particularly well-designed ergonomics, the Pill also offers high-quality sound reproduction, the result of numerous tests and adjustments.
The Moondrop Pill's circular dynamic driver offers excellent linearity, resulting in significantly reduced distortion compared to what is typically found in this type of earphone. With a diameter of 13mm, this speaker, accompanied by a large rear cavity, delivers deep bass and excellent dynamics.
Moondrop Pill earphones feature an adaptive bass enhancement algorithm that monitors audio signals in real time to improve bass reproduction. Finely calibrated by the Moondrop acoustics team, the Pill significantly improves bass performance while maintaining very low nonlinear distortion.
To ensure optimal sound quality, Moondrop uses the B&K5128 HATS for measurements and adjustments on the Pill. This method allows for natural sound reproduction. In addition, to improve the sound quality of these OWS (Open Wearable Stereo) earphones, a new VDSF reference curve is used to provide a more natural sound.
Moondrop Pill uses dipole directional sound transmission technology based on the principles of dipole sound sources. This innovative acoustic structure effectively cancels sound radiation outside the ear canal and eliminates up to 97% of sound leakage at a distance of 15cm from the ear, according to laboratory measurements conducted by Moondrop.
The Pill features an NPU (Neural Processing Unit) and incorporates an AI-powered ENC (Environmental Noise Cancellation) algorithm that has been extensively trained and optimized. Compared to traditional ENC algorithms, this advanced technology effectively eliminates noise while improving voice clarity.
The Moondrop Pill can connect to two different devices simultaneously. This allows you to quickly and easily switch between devices using the Moondrop app.
The C-shaped “bridge” of the Moondrop Pill combines liquid silicone with an internal titanium alloy wire structure for shape memory effect. This provides excellent wearing comfort while maintaining a certain elasticity even with repeated use.
The Pill earphones were designed for use on the go or during workouts. They feature an IPX4 waterproof rating, tested and certified by ILAC MRA and CNAS.
Moondrop Pill earphones feature a particularly efficient circuit that offers low power consumption. This allows you to enjoy 8+20 hours of playback or 35+90 hours of standby time (combined battery life of earphones and case).
The Pill features a quickly accessible game mode, reducing latency, and a music mode that optimizes sound quality. This allows you to enjoy both your games and your music in the best possible conditions.
With this new version of the Moondrop app, you can configure the equalization settings of the Pill's built-in DSP. All settings, including filter types, frequency management, and gain, are freely adjustable. The original frequency response is also displayed for reference.
The Moondrop Pill features an automatic equalization function. This allows you to simply select a target curve to activate audio optimization with a single click.
| Specifications | |
| Product type | OWS Clip-in earbuds |
| Bluetooth version | 6.0 |
| Bluetooth protocols | A2DP, AVRCP, HFP, HSP |
| Bluetooth codecs | SBC, AAC |
| Transmission range | 10m (barrier-free) |
| Battery life | Earphones: 8h (AAC mode) Charging case: 20h (AAC mode) |
| Battery capacity | Earphones: 3.7V 40mAh Charging case: 3.7V 300mAh |
| General | |
| Input voltage | 5VDC 1A |
| Output voltage | 5VDC 0.25A |
| Color | Black |
| Package | 1x Moondrop Pill 1x Charging cable |
| Color | Black |
| Impedance (Ω) | NC |
| Efficiency / Sensitivity (dB) | N/A |
| Wireless | Yes |
| Cable termination | Wireless |
| Headphone / Earphone connector | Wireless (Bluetooth) |
| Phone call feature | Yes |
| Noise reduction | Yes |
