TANCHJIM NORA In-Ear Monitors
Tanchjim Nora are dynamic in-ear earphones designed around the DMT5 transducer, developed to ensure accurate and controlled sound reproduction in a compact format. They are based on an acoustic architecture modelled by FEA and then machined by CNC, allowing fine control of internal volumes and optimised transmission of high frequencies, while maintaining distortion at 0.049% in order to preserve signal clarity across the entire spectrum, making them an ideal choice for monitoring applications.
Reference : 21420
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 07-04-2026.
Tanchjim Nora Dynamic In-Ear Monitors IEM 16 Ohm 125dB 2Hz-48hHz
Tanchjim Nora : Front view
Tanchjim
 Nora
are dynamic in-ear monitors designed around the DMT5 transducer, developed to ensure accurate and controlled sound reproduction in a compact format. They are based on an acoustic architecture modelled by FEA and then machined by CNC, allowing fine control of internal volumes and optimised transmission of high frequencies, while maintaining distortion at 0.049% in order to preserve signal clarity across the entire spectrum, making them an ideal choice for monitoring applications.
Tanchjim Nora : headphone on mixing console
Tanchjim Nora: Acoustic engineering
The acoustic architecture of Tanchjim Nora earphones is based on advanced FEA modelling, followed by CNC machining, a continuous design process that allows for precise control of internal volumes and signal propagation paths. This approach results in a measured improvement of approximately 10% in high-frequency transmission, reducing energy loss while increasing perceived resolution and micro-detail clarity.
Beyond internal optimisation, this structure also promotes enhanced sound insulation, limiting sound leakage while increasing the effectiveness of passive attenuation. Noise reduction thus reaches a depth of 35dB, preserving the integrity of the sound message in noisy environments without resorting to active processing.
Tanchjim Nora: DMT5 driver
The Nora earphones feature the DMT5 dynamic driver, based on a dual magnetic circuit combined with a dual acoustic chamber, a configuration that stabilises the magnetic field while finely controlling the behaviour of the diaphragm. This architecture promotes a more linear response under stress, while maintaining consistent dynamics across the entire spectrum.
The DLC (Diamond Like Carbon) composite diaphragm, coupled with a PU suspension, allows for significant membrane excursion without loss of control, combining impact in the bass and precision in the midrange. This approach is extended by an acoustic chamber based on the Helmholtz resonance principle, which is modelled using FEA to generate targeted reinforcement around 3 - 4.5kHz, a key range for presence and definition. The result is a total harmonic distortion (THD) of just 0.049%, ensuring a clean signal even at high levels.
Tanchjim Nora : DMT5 driver
Tanchjim Nora : Cable supplied and termination
Tanchjim Nora: Quality cable
The headphones come with a silver-plated copper cable made of Litz wires, a construction that limits skin effects and preserves signal consistency across the entire bandwidth. This approach is extended by an interchangeable termination, supplied with 3.5mm jack, 4.4mm jack and USB‑C connectors, allowing seamless integration with both analogue and digital sources.
Tanchjim Nora : Ergonomics
The geometry of the Nora's shell has been designed to fit the natural contours of the ear, while adjusting the centre of gravity to distribute weight evenly. This design reduces fatigue during long listening sessions, while maintaining stable positioning, which is essential for consistent sound reproduction.
Tanchjim Nora : in use
Product typeIn-ear monitors (IEM)
Driver typeDynamic
Earphone connectorsCIEM 0.78mm 2 pins
Cable connectorJack 3.5mm
Jack 4.4mm
USB-C
Frequency response2Hz-48hHz
Impedance16Ω ±5%
Total harmonic distortion (THD)0.049% @ 1kHz 94dB
Sensitivity125dB
Cable conductorsSilver-plated OFC copper
ColorWhite
Package1x Tanchjim Nora
1x CIEM cable 0.78 mm 2 pins
1x 3.5mm jack termination
1x 4.4mm jack termination
1x USB-C termination
6x Pairs of eartips (S / M / L)
ColorWhite
Impedance (Ω)16
Efficiency / Sensitivity (dB)125.0
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Cable terminationUSB-C
Phone call featureNo
Noise reductionNo
TANCHJIM NORA Dynamic In-Ear Monitors IEM 16 Ohm 125dB 2Hz-48hHz
Tanchjim Nora are dynamic in-ear earphones designed around the DMT5 transducer, developed to ensure accurate and controlled sound reproduction in a...
