TANCHJIM OLA BASS In-Ear Monitors IEM Dynamic Ø10mm 126dB 16 Ohm 7Hz-45kHz
The Tanchjim Ola Bass in-ear monitors offer a remarkable level of design quality and sound reproduction at an affordable price. Each IEM (In-Ear Monitor) is equipped with a 10mm diameter dynamic driver. The diaphragm utilizes a composite material typically found in high-end models. The DMT4 dynamic driver enables these earphones to deliver excellent responsiveness, delicate high frequencies, and deep bass.
Reference : 17774
46,90 €tax incl.
39,08 € tax excl.
TANCHJIM OLA BASS
Dynamic IEM Earphones Ø10mm 126dB 16 Ohm 7Hz-45kHz
TANCHJIM OLA BASS Écouteurs Intra-Auriculaires IEM Dynamiques avec Microphone Ø10mm 126dB 16 Ohm 7Hz-45kHz
The Tanchjim Ola Bass in-ear monitors offer a remarkable level of design quality and sound reproduction at an affordable price. Each IEM (In-Ear Monitor) is equipped with a 10mm diameter dynamic driver. The diaphragm utilizes a composite material typically found in high-end models. The DMT4 dynamic driver enables these earphones to deliver excellent responsiveness, delicate high frequencies, and deep bass. Additionally, this model is equipped with a small control box on its cable, which includes a microphone, making it easy to answer calls.
High quality cable
The cable of the Tanchjim Ola Bass is made of 4 silver-plated OFC (Oxygen-Free Copper) conductors with kevlar reinforcement and anti-oxidation treatment. However, the cable remains perfectly flexible.
Secure connections
The cable features a double-pin CIEM 0.78mm connector on the earphone side, providing a stable and efficient connection.
Product typeIn-Ear Monitors (IEM)
Speaker typeØ10mm Dynamic
Speaker technologyDMT4
MembraneFlexible suspension made of ultrafine fibers + PEEK
Sensitivity126dB/Vrms @1Khz
Impedance16Ω ±10% @ 1kHz
THD< 0.3% @1kHz
Frequency response7Hz - 45kHz
Cable length125cm
Cable conductor materialSilver plated OFC copper Litz wire
ConnectorJack 3.5mm
ColorSilver
ColorTransparent
Impedance (Ω)16
Efficiency / Sensitivity (dB)126.0
Lowest frequency (Hz)7
Highest frequency (Hz)45000
WirelessNo
Cable terminationJack 3.5mm
Phone call featureNo
Noise reductionNo
The Tanchjim Ola Bass in-ear monitors offer a remarkable level of design quality and sound reproduction at an affordable price. Each IEM (In-Ear...
