Truthear's Hexa are high-performance in-ear monitor combining a dynamic driver and three balanced armature drivers with a hybrid structure for very natural bass and midrange sound reproduction, and treble reproduction that varies greatly according to the type of eartip used: clear and natural when used with silicone eartips, and softer and more delicate when used with foam eartips.
Hexa uses four drivers to effectively cover the entire frequency range. Low frequencies are handled by a Ø10mm dynamic driver with a liquid crystal polymer (LCP) diaphragm and polyurethane suspension. The weighted voice coil used has been specially selected to reduce the driver's resonant frequency and increase its impedance, delivering furthermore punchy bass and meeting the need for precise frequency range distribution.
A pair of composite balanced armature drivers are responsible for the midrange, which has been specially tuned to precisely complement the dynamic driver while rigorously conforming to HRTF characteristics.
Finally, a custom balanced armature tweeter, with characteristics very similar to Knowles' WBFK series, is responsible for high frequencies, not only effectively complementing the frequency band coverage, but also offering a fine, precise rendering of high frequencies.
The Hexa's internal cavity has been machined using DLP (Digital Light Processing) 3D printing, a process that enables an otherwise impossible level of design finesse to be achieved. As a result, Truthear was able to design a waveguide structure adapted to each driver, merging their renderings into a coherent whole as close as possible to what the brand wished for in terms of sound reproduction.
All this engineering gives Hexa a sound reproduction with powerful bass without being intrusive, natural midrange and bass, with no clear cross-hatching between the different drivers, and treble whose reproduction is greatly modified according to the type of tip used: clear and natural when used with silicone tips, and softer and more delicate when used with foam tips.
The Hexa comes with a 1.20m silver-plated copper 3.5mm to 0.78mm 2-pin jack cable, guaranteeing high-quality signal transmission without external interference.
Product type | In-ear monitors (IEM) |
Speakers type | 1x Dynamic driver 3x Balanced armature drivers |
Dynamic driver diaphragm | Ø10mm in liquid crystal polymer (LCP) |
Impedance | 20.5Ω ±15% @ 1kHz |
Sensitivity | 120dB @ 1kHz |
Total harmonic distortion (THD) | ≤ 1% @ 1kHz (94dB) |
Frequency response | 5Hz-40kHz |
Cable | Detachable |
Cable length | 1.2m |
Earphone connectors | 0.78mm 2 pins |
Cable termination | Jack 3.5mm |
Cable materials | Silver-plated copper |
Color | Black |
Package | 1x Truthear Hexa 1x 3.5mm jack to 0.78mm 2-pin cable 1x Carrying bag 7x Pairs of ear tips |
Color | Black |
Impedance (Ω) | 20 |
Efficiency / Sensitivity (dB) | 120.0 |
Lowest frequency (Hz) | 8 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Headphone / Earphone connector | CIEM |
Phone call feature | No |
Noise reduction | No |
