AUDIOPHONICS DA-S125NC Class D Integrated Amplifier NCore NC122MP DAC ES9038Q2M Bluetooth 2x125W 4 Ohm 32bit 768kHz DSD256
-16%
Versatile and powerful, we offer you with DA-S125NC an integrated amplifier with digital inputs to which you can add speakers to enjoy your music in the best possible way. Combining a comfortable power amplification, a powerful DAC, a complete connectic and a precise volume control, this amplifier is a must have for those who wish to equip themselves with a qualitative sound system without having to add a multitude of devices dedicated to specific functions.
Reduced price!
Reference : 17064
Limited special offer
579,00 €tax incl.
-16%
489,00 €tax incl.
407,50 € tax excl.
Audiophonics Workshop amplifiers range
Audiophonics DA-S125NC
Class D Integrated Amplifier NCore NC122MP DAC ES9038Q2M Bluetooth 5.0 2x125W 4 Ohm 32bit 768kHz DSD256
Audiophonics DA-S250NC Amplificateur Intégré Class D NCore DAC ES9038Q2M Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DSD512
Versatile and powerful, we offer you with the DA-S125NC an integrated amplifier with digital inputs to which you can simply add speakers to enjoy your music in the best possible way. Combining a comfortable power, a powerful DAC, a complete connectic and a precise volume control, this amplifier is a must have for those who wish to equip themselves with a qualitative sound system without having to add a multitude of devices dedicated to specific functions.
Audiophonics DA-S125NC Amplificateur Intégré Class D NCore DAC ES9038Q2M Bluetooth 5.0 2x125W 4 Ohm 32bit 768kHz DSD512
Incredibly effective amplification
Real engine of this DA-S125NC, the Hypex NCore NC122MP Class D amplifier module delivers a comfortable power, up to 2x125W under 4Ω, with great efficiency and ease, while maintaining a compact size. Its main characteristic is revealed in its great linearity and its ability to ensure a very low level of distortion. The DA-S125NC reveals a sound reproduction as transparent as detailed to present you your music as close as possible to its recording in studio.
The NCore NC122MP module also features its own SMPS power supply, consisting of a regulated half-bridge converter with synchronous rectification on the main output rails. This design is ideally suited for integration with a Class D amplifier, providing the amplifier with a stable, clean electrical signal and capable of responding quickly to more sudden power requirements.
Enjoy your music in every detail
The DA-S125NC's digital-to-analog conversion is handled by a widely proven and audiophile-approved DAC, the ES9038Q2M from ESS Technology. This chip uses the patented HyperStream® II 32bit architecture and Time Domain Jitter Eliminator technology to deliver excellent performance. The result is incredibly accurate sound reproduction that captures every detail of your music.
This DAC also opens the door to very high resolution, supporting PCM audio streams up to 32bit 768kHz and DSD up to DSD256.
A complete connectivity to adapt to all your needs
The DA-S125NC offers a complete range of connections to easily integrate into your audio system and adapt to your use. Its rear panel features digital inputs, coaxial, optical Toslink and USB-B (XMOS). For the outputs, you can of course count on high quality speaker terminals, but also on a Pre-Out output via RCA.
This RCA output offers you several possibilities:
- to connect an active subwoofer
- to connect another integrated amplifier
Broadcast from your couch
In addition to its physical connectivity, the DA-S125NC provides you with a high quality Bluetooth 5.0 reception capability. Extremely practical, it will allow you to broadcast and control your music wirelessly quickly and easily, directly from your smartphone or tablet for example.
A sober and modern design
The components are perfectly protected by a robust aluminum case. Optimal heat dissipation is provided by a series of openings on the cover and rear panel, allowing for good airflow. The front panel of the DA-S125NC features a beautiful black acrylic panel, a modern and elegant aesthetic touch. Behind this panel is a beautiful OLED display that shows the volume level, the active input and the type of signal received by the device. It will also allow you to navigate through the menus and access all the options of the DA-125NC.
Product typeIntegrated amplifier
InputsBluetooth 5.0
1x USB-B
1x Coaxial
1x Optical Toslink
OutputSpeaker terminals
1x Stereo RCA pre-out
AmplifierHypex NCore NC122MP
DACESS ES9038Q2M
USB interfaceXMOS XU208
Output power2x 125W @ 4Ω, 1kHz, THD 1%
2x 60W @ 8Ω, 1kHz, THD 1%
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD DoP up to DSD256
Coaxial / Optical : PCM up to 24bit 192kHz, DSD DoP up to DSD64
THD+N0.0015%
SNR118dB
OLED screenBrightness not adjustable, but turns off after 40 seconds
Supply voltage110-230V AC
ColorGray
Total dimensions (WxDxH)300*291*60mm
Weight2.4kg
CaseAll brushed aluminium / Black acrylic front
Package1x Audiophonics DA-S125NC
1x Remote control (batteries included)
1x Power cable
1x Bluetooth antenna
Mesure FFT - 5W - 4 Ohm
FFT DA-S250NC - 5W - 4 Ohm
Mesure FFT - 4.4V Rms à vide
FFT DA-S250NC - 5W - No load
ColorGray
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)250.0
Remote ControlYes
2 reviews
Très étonnant !!!
Félicitations audiophonics, envoie rapide, emballage sérieux.
Ai eu plusieurs amplis intégrés, classe AB, CLASSE T, tube...
Dans le cas de cet intégré, conseillé par un ami c'est une excellente surprise !!
Il sort à peine du carton et déjà grave ( Hp de 38) profond et très articulé, scène sonore large et profonde, beaucoup de nuances, détails abondants, son reposant sans aucune acidité.
A ce prix... pourquoi dépenser plus, bravo audiophonics.
This review has been posted for AUDIOPHONICS DA-S125NC Class D Integrated Amplifier NCore NC122MP DAC ES9038Q2M Bluetooth 2x125W 4 Ohm 32bit 768kHz DSD256
Great product
Purchased to pair with B&W bookshelf speakers in my bedroom system.
Fantastic DAC + ampli combination for both sound and ease of use (small footprint and clean, no frills industrial design) at a very attractive price. Connected to a DVD player and an Apple TV using coax and optical (Apple TV is also used to stream music from Qobuz app). Power is more than adequate for the room and speakers used, which never sounded so good. Highly recommended.
Very good service by Audiophinics (advice, fast shipping, support), as always.
Versatile and powerful, we offer you with DA-S125NC an integrated amplifier with digital inputs to which you can add speakers to enjoy...
