AUDIOPHONICS TPA-S100 Amplifier Class D TPA3255 Bluetooth 5.0 2x 85W 4 Ohm Black
With the Audiophonics TPA-S100, we offer you a Class D amplifier benefiting from a beautiful design, allowing it to deliver a comfortable power of 2x85W under 4Ω. It uses a Texas Instruments TPA3255 amplifier chip, characterized by a low distortion and a very low noise floor, for a precise and dynamic sound reproduction.
4.8 / 5
Reference : 15546
199,00 €tax incl.
165,83 € tax excl.
This product is temporarily unavailable.
AUDIOPHONICS TPA-S150 Amplificateur TPA3255 Class D Bluetooth 5.0 2x 150W 4 Ohm Noir
In addition to its two analog stereo RCA inputs and USB-B input, it also benefits from Bluetooth 5.0 connectivity thanks to the Qualcomm QCC3034 receiver chip. This ensures stable reception and allows you to take advantage of the high resolution codecs aptX and aptX HD. A DAC PCM5102 is responsible for decoding audio streams received via USB or Bluetooth.
We also find within the circuits of this TPA-S100 three AOP JRC 5532DD for its preamplifier stage or a volume and tone controller JRC NJW1194.
Finally, the amplifier includes a custom isolated and filtered power supply stage, allowing the delivery of a constant and clean electrical signal to the audio circuits.
Product typeAmplifier
Amplifier typeClass D
InputsBluetooth 5.0
1x USB-B
2x Stereo RCA
OutputSpeaker terminals
Bluetooth codecsSBC, AAC, aptX, aptX-HD
Supported sampling ratesUSB / BT: PCM up to  16bit 48kHz
Output power2x85W @ 4Ω (THD 0.003%)
2x100W @ 4 Ω (THD 10%)
Frequency response18Hz-25kHz
Tone adjustment (bass/treble)±10dB
Distortion0.003%
SNR111dB
Supply voltage100-240VAC 50/60Hz
Housing materialAluminum
Dimensions240 x 197 x 60mm
Weight2.02kg
Package1x Audiophonics TPA-S100
1x Remote control
1x Bluetooth antenna
1x Schuko Power cable
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)85
Remote ControlYes
6 reviews
Très bon produit
J'ai commandé cet amli depuis la Nouvelle Calédonie, le suivi de la livraison a été clair, livraison rapide sans ennui.
L'ampli en lui même est compact, simple, il n'y a que deux boutons et une télécommande. Le bluetooth marche super bien. Le son délivré est très satisfaisant sur mes enceintes caisson équipées de haut parleur Supravox.
Un rapport qualité prix excellent !!!
Aymeric
This review has been posted for AUDIOPHONICS TPA-S100 Amplifier Class D TPA3255 Bluetooth 5.0 2x 85W 4 Ohm Black
un bon petit ampli
agréablement surpris par cet ampli, la construction inspire confiance, et le son est bien la, fidéle et équilibré.
je l'ai connecté a des tangent evo 4 puis des davis acoustics monitor one avec un baladeur fiio m11 en bluetooth, le résultat est a la hauteur, trés neutre.
pas encore essayé avec des colonnes.
quand a l'emballage, inexistant, tout comme le mode d'emploi, la télécommande dont la plupart des fonctions sont inopérantes,
peu importe, l'essentiel est la (tout comme l'antenne bluetooth non mentionnée).
si il fallait faire un reproche, ce serait le manque d'entrées numériques, effectivement pas de coaxial ni d'optique, a prendre en considération lors de l'achat.
4.5 stars
+ good looking, seems to be solidly build
+ no background noise present (up to e.g. -20db gain I've to put my ear directly to the speaker to hear some noise] - I was afraid of the noise quite often being problem of class D amplifiers so I'm really happy it is bot the case of this one
+ usable for driving speakers in small living room way below maximum possible power
+ APTX-HD and AAC bluetooth codecs
- USB DAC resolution (16bit/48khz) is not what one would expect from today's products (otherwise I would give 5 stars)
Un très bon ampli
Dès réception, déballage et attente que l'appareil soit a la température ambiante avant la mise sous tension. Le coffret est d'une très belle fabrication. Après quelques heures d'attente, mise sous tension et puis fonctionnement pendant quelques dizaines d'heures avec de la musique avant de faire une écoute objective.
Essai avec des enceintes bibliothèque équipées d'un 13cm + tweeter Dayton, le rendement de ces enceintes est de 85dB/W/m. L'ensemble est homogène, bonne tenue dans le grave, clarté, dynamique, tout est là.
Essai avec des enceintes très haut de gamme avec des 38cm qui ont une bobine mobile de 100mm et des tweeters Heil AMT et dont le rendement est de 100 dB/W/m. Premier constat, le rapport signal bruit est excellent, il faut approcher son oreille a quelques centimètres du tweeter pour deviner un très léger souffle. J'ai été bluffé par la tenue du grave de cet ampli, il montre une petite "faiblesse" lorsque il y a de l'infra, mais c'est beaucoup lui demander. Sur le reste du spectre, un léger manque de "chaleur" sur les voix et une très légère brillance sur l'aigu. Cette comparaison a été faite avec des électroniques "haut de gamme".
Conclusion: Un excellent petit ampli que je recommande.
Un petit plus serait d'avoir une notice sur la télécommande, certaines touches ne correspondent pas aux indication, il suffit de quelques minutes avant de découvrir toutes les fonctions.
Pairs as BT device HiFi-IIS
Pairs as BT device HiFi-IIS on my iPhone. Found some loose screws inside and had to open it and remove it. To early to say anything about sound quality.
With the Audiophonics TPA-S100, we offer you a Class D amplifier benefiting from a beautiful design, allowing it to deliver a comfortable power of...
