By buying this product you get 599 loyalty points
Amplifier Class AD 4x200W / 2x400W 4Ω
Rose HiFi offers with its RA180 a high-end integrated amplifier at the cutting edge of innovation, integrating modern technologies within an intelligent architecture. It offers a greatly improved linearity by reducing the power damping for an incredibly transparent sound reproduction. In addition, it has a beautiful design, the crossroads between vintage and modernity.
A true revolution in the world of amplification, Rose HiFi unveils an innovative Class AD architecture taking advantage of both the benefits of Class A/AB amplifiers and Class D structures. This particular design allows for improved linearity, in particular through the use of a new material, GaN (Gallium Nitride).
Furthermore, the RA180 opens the doors to bi-amplification by integrating four independent amplifier modules. Each module supports a response up to 100kHz, allowing the use of super tweeter.
To power these modules, the RA180 features a massive power stage capable of delivering 1100W of power to meet the needs of the most demanding audio systems.
In terms of power amplifier design, the Class D topology theoretically offers full linear output at 0% distortion and 100% efficiency. To achieve this theoretical perfection, the speed and accuracy of switching operations must be secured.
To correct this concern, the RA180 features a perfectly linear output using a Gallium Nitride FET instead of a silicon FET which directly affects the switching accuracy and speed. This fully linear output exceeds the capabilities of the Class D topology and allows for a natural sound reproduction, close to that of an analog amplifier.
The RA180 offers a stereo output and provides two channels for each right and left output. Each amplifier offers a power of 200W under 4Ω and 8Ω, allowing a bi-amplification integration, in order to feed separately the different channels of your speakers and offer a more natural and musical restitution. It is also possible to activate the BTL mode to reach a power of 2x400W.
The RA180 is able to reproduce the original audio signal as closely as possible by covering an extremely wide frequency range. Thus, even the highest frequencies are not filtered out, with a frequency response ranging from 20Hz to 100kHz (±1dB).
The Rose HiFi RA180 can be used with both MM and MC turntables. To adapt to different recordings and audio systems, it integrates TurnOver and Roll-Over filters with an extremely precise equalization system.
The RA180 has H/F speaker outputs and an active crossover function to adjust the response when using a super tweeter.
The RA180 offers a linear reproduction for the most faithful reproduction of the original signal. However, it offers a tone control that allows you to adjust the bass (100Hz) and treble (10kHz) levels over an adjustable range of ±15dB. This makes it possible to adapt the output of the amplifier to your audio system and your listening preferences. The tone control circuit is equipped with a high fidelity active equalizer (type AOP: 12dB slope) rather than a passive system (type CR: 6dB slope).
The on-board power supply has been developed specifically for the RA180 and does not use silicon FETs but silicon carbide FETs. These allow high power and efficiency to be achieved with low heat generation. A 2.5kW PFC circuit and a high capacity capacitor allow the RA180 to respond quickly to high power requirements.
The RA180's remote control allows you to remotely control the volume level by acting directly on the motorized potentiometer, and also to select an input. In addition, the LED indicators on the source selector automatically detect input signals, with a flashing light indicating that a signal is being received.
The RA180's Bypass - Power Amp mode connects the LINE 3 input directly to the power amplifier, without passing through the preamplifier stage. Furthermore, the unit also offers the possibility to select an active speaker group easily by means of a switch.
| 1 | Preamplifier |
| 2 | Level indicator |
| 3 | Volume |
| 4 | Speaker selector |
| 5 | Bypass · Power Amp mode switch |
| 6 | Input selector |
| 7 | Operating mode selector switch |
| 8 | Active crossover |
| 9 | Phono amplifier equalizer |
| 10 | Volume button |
| 11 | LED brightness selector |
| 12 | Switch ON/OFF subsonic filter |
| 13 | Switch ON/OFF attenuator |
| 14 | Phono GND |
| 15 | Balanced XLR input |
| 16 | BTL Output - Right channel |
| 17 | BTL Output - Left Channel |
| 18 | Reset button |
| 19 | Power connector |
| 20 | RCA Phono input |
| 21 | RCA single-ended inputs |
| 22 | Phono MM/MC mode switch |
| 23 | Subwoofer output |
| 24 | BTL switch |
| 25 | Trigger input |
| 26 | IR input |
| 27 | GND |
| Spécifications | ||
| Product type | Class AD Amplifier | |
| Output power | 4x 200W @ 4Ω 4x 200W @ 8Ω 2x 400W @ BTL Mode ON | |
| Input sensitivity | Balanced : 2000mV Single-ended : 1000mV Phono (MM/MC) : 5mV / 0.5mV | |
| Input impedance | Balanced : 44kΩ Single-ended : 47kΩ Phono (MM/MC) : 47kΩ | |
| Bandwidth (0dBr±3dB/8Ω) | Speaker output : 10Hz ~ 90kHz H/F speaker output : 10Hz ~ 90kHz | |
| Frequency response (1W±1dB/8Ω) | Speaker output: 10Hz ~ 90kHz H/F speaker output: 10Hz ~ 90kHz | |
| THD | 0.005% (50W) | |
| Damping factor | > 150 | |
| SNR | BTL : 107dB Balanced, single-ended: 105dB Phono (MM/MC) : 80dB / 60dB | |
| Output impedance | 53mΩ | |
| Subsonic filter with ON/OFF switch | 50Hz (-3dB) | |
| Tone control with ON/OFF switch | ±15dB (Bass: 100Hz / Treble: 10kHz) | |
| Crossover with ON/OFF switch | 600Hz ~ 6kHz (HPF -3dB) | |
| Phono | Turnover | Flat 300Hz (+7.7dB @ 100Hz) 400Hz (+11.7dB @ 100Hz) 500Hz (+13dB @ 100Hz) (RIAA) 700Hz (+14.5dB @ 100Hz) |
| Roll-Off | Flat 1.6kHz (-16dB @ 10kHz) 2.1kHz (-13.7dB @ 10kHz) (RIAA) 3.18kHz (-11dB @ 10kHz) 3.4kHz (-8dB @ 10kHz) 6.36kHz (-5dB @ 10kHz) | |
| Trigger voltage | 3.3V ~ 12V | |
| General | |
| Dimensions | Without feet: 430 x 350 x 110mm With feet : 430 x 391 x 130mm |
| Weight | 16.7kg |
| Housing material | Aluminum |
| Supply voltage | 100-230VAC 50/60Hz |
| Input | RCA |
| Input | Phono |
| Input | XLR |
| Output | Subwoofer |
| Output | Speaker terminal |
| Color | Silver |
| Channel | 4 |
| Channel | 4.1 |
| Channel | 2 (Stereo) |
| Channel | 2.1 |
| Class | Class AD |
| Amplifier chip | N/A |
| Power (W) | 200.0 |
| Power (W) | 400.0 |
| Remote Control | Yes |
