3E AUDIO A5 Amplifier
3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A5 amplifier is based on two TI TPA3251 chips in PBTL configuration, and two dual OPA1656 OPAs. This means it can deliver up to 2x150W into 4 ohm.
By buying this product you get 27 loyalty points
Reference : 20375
279,00 €tax incl.
232,50 € tax excl.
Shipping date: 19-05-2026.
3E Audio A5Class D Stereo Amplifier PBTL 2xTPA3251 2x150W 4 ohm
Photo of 3E Audio A5
3E Audio,
In terms of connectors, the 3E Audio A5 features an RCA input, a practical balanced XLR/Jack 6.35mm combo input, and an output on speaker terminals. The RCA input gain can be adjusted (LOW=23dB, HIGH=26dB), and the preamplifier stage and volume control can be bypassed for use as a power amplifier. Versatile and high-performance, this little amplifier is able to offer a good reserve of power while preserving the final sound reproduction.
Product update
In response to feedback from the Audio Science Review community, 3E Audio has made a number of modifications to its amplifiers.
  • Auto power off time set to 20 mins.
  • Increase audio detection sensitivity RCA: 200uVrms; XLR: 400uVrms,this significantly meet some user listening in very very low volume.
  • Auto audio sensing power on/off can be disable/enable by user. To do so, simply press and hold the 5 seconds volume button in standby mode, and the RCA LED will flash for 3 seconds to deactivate it. To reactivate, follow the same procedure, but the XLR LED flashes for 3 seconds.
A7
A7se
A7 Mono
A5se
A5
Amplification chip
2x TPA3255
2ch - PBTL
1x TPA3255
2ch - BTL
1x TPA3255
1ch - PBTL
1x TPA3251
2ch - BTL
2x TPA3251
2ch - PBTL
Output power
(4 ohm, THD+N=1%)
2x 250W
2x 230W
1x 260W
2x 140W
2x 150W
Output power
(8 ohm, THD+N=1%)
2x 140W
2x 130
1x 150
2x 70W
2x 80W
Load impedance
2-16 ohm
4-16 ohm
2-16 ohm
4-16 ohm
2-16 ohm
3E Audio A5: Two TPA3251 chips
The two TPA3251 amplifier chips offer a consistent level of output power, as the 3E Audio A5 delivers up to 2x150W into 4 ohm and up to 2x80W into 8 ohm (THD+N = 1%). In addition, the PBTL configuration maintains continuous, stable output power while reducing power losses. It also enables the amplifier to withstand loads of up to 2 ohms.
TPA3255 chips
Interchangeable DIP8 OPAs
3E Audio A5: Interchangeable OPAs
The preamplifier stage of the 3E Audio A5 is made up of two double OPA1656 OPAs mounted in DIP 8 and easily replaceable with pliers, thanks to the design of the case. In fact, the OPAs can be accessed through two hatches without opening the case. Here's a non-exhaustive list of compatible OPAs: OPA1656, OPA1602, OPA2134, NE5532P, LME49720, LM4562, MUSES02, MUSES8920, NJM4580, NJM4556, NJM2068, OP249, AD827, etc.
Please take care not to damage the device or the OPAs when replacing or handling them. Any damage to the device caused by improper handling by the user (reverse mounting of OPAs, mounting of non-compatible OPAs, etc.) will invalidate the product warranty. Please refer to the manual to carry out the operation.
3E Audio A5: Quality components
Rubycon 63V 1000uF capacitors
Rubycon capacitors meet high current requirements, reducing noise and improving THD.
Flat wire coils
Flat-wire coils
The coils used in the amplifier provide improved linearity and reduced distortion, while delivering the best performance whatever the impedance load.
TDK capacitors
TDK capacitors
These highly reliable LC filter capacitors ensure optimum audio performance.
3E AUDIO A5 amplifier PCB photo
3E Audio A5 overview
Overview of the 3E Audio A5
1Left channel status LED
2RCA input status LED
3Multifunction button
4XLR input status LED
5Right channel status LED
6Balanced XLR/Jack 6.35mm combo input
7RCA input
8RCA gain control
9Speaker terminal output
10Volulme bypass
1136V-38V DC power supply via DC jack
3E AUDIO A5 review by Audio Science Review
" The A5 amplifier is very well thought out small amplifier with excellent feature set and performance to back it. I love features such as clipping indicator to tell you whether you are exhausting all of its power. Measurements show one of the most implementations of this architecture with no weak point other than perhaps, high frequencies. All of this for a reasonable price. I am happy to recommend the 3e-audio A5 stereo amplifier. "
Product typeClass D amplifier
ChannelsStereo
Amplification chip2x TI TPA3251
OPADual OPA OPA1656
StructurePFFB
Inputs1x Single-ended RCA input
1x Balanced XLR/jack 6.35mm combo input
Output1x Speaker terminal output
Input impedanceRCA : 10kΩ
XLR/TRS : 20kΩ
Volume attenuation-50dB
Volume bypass
RCA gain control
Audio specifications (RCA IN)
THD+N (5W)0.0004% @ 4Ω
0.0005% @ 8Ω
SNR (1% THD+N, 1KHz, A-wt)123dB
Dynamic range (1% THD+N, 1KHz, A-wt)123dB
Frequency response (±0.5dB)20Hz-35KHz
Noise (A-wt)< 15uVrms
Crosstalk-100dB
Gain23dB / 26dB
Input sensitivity1.75Vrms
Output power (1% THD+N)2x 150W @ 4Ω
2x 80W @ 8Ω
Output power (10% THD+N)2x 180W @ 4Ω
2x 100W @ 8Ω
Output impedance2Ω-16Ω
audio specifications (XLR IN)
0.0003% @ 8Ω
SNR (1% THD+N, 1KHz, A-wt)125dB
Dynamic range (1% THD+N, 1KHz, A-wt)125dB
Noise (A-wt)< 13uVrms
Crosstalk-110dB
Gain17dB
Input sensitivity3.5Vrms
2x 800W @ 8Ω
2x 100W @ 8Ω
Supply voltage36V-38V DC 5A (The supplied power supply operates on 110V and 230V)
Power consumptionOFF: <0.2W
ON (no audio): 8W
Dimensions170 x 168 x 46mm
Weight1000g
Package1x 3E Audio A5 amplifier
1x 38V 5A power adapter
InputXLR
InputJack 6.35mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3251
Power (W)150.0
5 reviews
very fine amplifier
I use it with Dali Oberon 3 and a Fosi audio ZD3 DAC (XLR connection) after replaced a Fosi V3 stereo (RCA) and the improvement is surely noticeable with a clean sound, a little better bass, no hiss noise in silence from tweeters (extremely low noise -inaudible). The volume bypass and standby mode are its main advantages to get & with quality input/outputs connectors. I wouldn't expect and ask something more for the cost it has. Many Thanks to Audiophonics for the opportunity to offer it in stock and for the quick/safe shipping
This review has been posted for 3E AUDIO A5 Class D Stereo Amplifier PBTL 2xTPA3251 2x150W 4 ohm
Le respect absolu de la "magie" des tubes
Une claque auditive ! Pour tout passionné, l'ajout d'un bloc de puissance est souvent un dilemme : comment gagner en puissance sans trahir la signature sonore patiemment construite ?
Ma configuration repose sur un TAGA Harmony HTA-700 sublimé par des Gold Lion CV4004 appairées et des stabilisateurs HAL-O III Stabilizer. Un ensemble qui offre un grain et une chaleur magnifiques. Ma crainte était qu'un ampli de puissance vienne gommer cette identité.
Le 3E AUDIO A5 s’est révélé être le chaînon manquant. C’est un véritable gain : il s’efface totalement derrière la source. Je retrouve toute la richesse harmonique et la finesse de mes Gold Lion, mais avec une assise et une dynamique transfigurées. Sa neutralité est exemplaire, surtout quand on sait qu'il surclasse des références coûtant bien plus cher.
Côté logistique :
Performance & Rendu : ❤️❤️❤️❤️❤️ Une transparence chirurgicale qui ne sacrifie jamais l'émotion.
Logistique : ❤️❤️❤️❤️❤️ Expédition éclair, reçu en 24h chrono.
Service Client :
Superbe!
Bonjour, associé à des boules elipson planet performance le résultat est superbe de finesse et d’équilibre. J’ai eu de gros amplis lampes ou transistor en classe AB et c’est mon premier classe D. Vu la taille de cette petite merveille, l’effet waouh est obligatoire.
A titre d’info, à un bon volume sonore (limite appel des voisins), je suis environ à la moitié de la puissance disponible à trois mètres. Entrée RCA et bypass, la qualité est bien là et mon vieux ampli arcam 16 kilos va prendre du repos.
Question chaleur? RAS, tout juste tiède donc loin de mes appréhensions.
D’un rapport qualité/prix étonnant, mon WiiM pro + a trouvé ses compagnons de jeux formant un ensemble d’une qualité inespérée.
Outstanding value
le petit qui joue dans la cour des grands
J’ai des enceintes à haut rendement et avec la plupart des amplis que j’ai déjà essayés, un souffle se manifeste, en particulier sur les moteurs à compression. J’ai acheté trois A5 pour réduire le souffle dans mon système, vu que le A5 a un bruit résiduel extrêmement bas. Avec les A5, sur les moteurs à compression, on entend toujours un léger souffle, mais cela est dû au bruit qu’il y a en amont des amplis : c’est mon processeur qui génère un souffle. Ce n’est donc pas la faute du A5 qui ne fait qu’amplifier ce qu’on lui donne, donc aussi le bruit. Quand je branche les A5 directement sur les moteurs à compression sans processeur, le souffle disparaît presque complètement.
J’ai déjà eu plusieurs amplis classe D d’origine professionnelle (Crown XLS Drivecore, Crest Pro-LITE, QSC PLD …). J’ai toujours été charmé par le son audiophile de ces amplis, mais sur mes enceintes à haut rendement, ces amplis pro augmentent le bruit qu’il y a dans ma chaîne. Le A5 fait preuve lui aussi d’une grande musicalité, mais il n’ajoute pas de souffle au système. On est très loin du son maigre et froid de certains amplis de classe D venant du monde hifi. Les timbres ne sont pas dénaturés et le rendu sonore se caractérise par une grande clarté et par une belle fluidité. Cela n’étonne pas : certains composants sont de très bonne qualité (alimentation, condensateurs, puce …). Ajoutons à cela que le A5 offre une puissance respectable malgré sa taille réduite. En plus, le A5 est indépendant de la charge : cela est rendu possible par le ‘post filter feedback design’ (PFFB) et par les caractéristiques de la puce TI. Cela donne un son très équilibré. La scène sonore est précise, large et profonde.
Conclusion : petite taille, petit prix mais grand son.
3E Audio, a recognized player in the DIY world, now offers a Class D Stereo amplifier incorporating audiophile Hi-Fi components. The A5 amplifier...
