AIYIMA A07 MAX Stereo / Mono Class D Amplifier TPA3255 2x225W 4 Ohm / 1x315W 4 Ohm
This small Class D Aiyima A07 MAX amplifier offers stereo as well as mono operation, so you can chain several A07 amplifiers together for extra power. This amplifier embeds a TI TPA3255 amplifier chip and is capable of developing a power of 2x225W @ 4Ω in stereo or 1x450W @ 4Ω in mono.
3.8 / 5
Reference : 18403
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 26-06-2025.
AIYIMA A07 MAX
AIYIMA A07 MAX Stereo / Mono Class D Amplifier TPA3255 2x225W 4 Ohm / 1x450W 4 Ohm
This small Class D Aiyima A07 MAX amplifier offers stereo as well as mono operation, so you can chain several A07 amplifiers together for extra power. This amplifier embeds a TI TPA3255 amplifier chip and is capable of developing a power of 2x225W @ 4Ω in stereo or 1x450W @ 4Ω in mono. Its NE5532 OPAs are DIP8 mounted and therefore easily replaceable (AOP OPA2604AP, OPA2134, MUSEO1/02/03, LME49720NA, LM4562, AD827AQ, etc). High-quality internal components, such as WIMA and Rubycon capacitors and a TI364 power management chip, ensure excellent performance. Connectivity features the essentials: RCA line input, speaker terminals and AUX output on 3.5mm jack. The AUX output can be used to connect an additional amplifier in mono mode, or an active subwoofer.
A TI TPA3255 amplification chip
Inside the Aiyima A07 MAX is a TI TPA3255 chip coupled to NE5532 DIP8-mounted AOPs. This is what enables it to develop its high power output, as well as an SNR ≥ 110dB and a THD of 0.007%.
Mono mode activation and configuration examples
To activate mono mode, simply flip a switch on the underside of the unit. Mono output is then routed to the upper speaker terminals. Several configurations are possible with this feature: stereo mode, single mono mode and multi-device mono mode.
Stereo mode
Single mono mode
Multi-device mono mode
AIYIMA A07 MAX rear panel
La sortie AUX est fixe. Le contrôle de volume n'a donc aucun impact sur elle.
Product typeAmplificateur stéréo/mono Class D
Amplification chipTI TPA3255
OPAOPA5532
Inputs1x Stereo RCA line input
Outputs1x AUX 3.5mm jack output
Speaker terminals
THD0.007%
SNR≥ 110dB
Input sensitivity1V
Fréquency response20Hz-20KHz(±1dB)
Max. AUX output level1V
Power supplyDC 24V-48V (power supply not included)
Dimensions265 x 240 x 65mm
Gross weight (package)1.27kg
Package1x Amplifier AIYIMA A07 MAX
OutputJack 3.5mm
OutputSpeaker terminal
ColorGray
Channel1 (Mono)
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)225.0
5 reviews
Respectable
Ce petit ampli reste correct, même après une 50 aine d'heures d'écoute et alimenté en 48V 7.3A, c'est plat, sans. Je le garde en spare au cas où, mais n'en acheterai pas d'autre. Rien de comparable à un Fosi ZA3.
This review has been posted for AIYIMA A07 MAX Stereo / Mono Class D Amplifier TPA3255 2x225W 4 Ohm / 1x315W 4 Ohm
AiYIMA A07 MAX en 2 Blocs Mono
J'utilise deux amplis A7 MAX configurés en Mono pour une écoute stéréophonique (L&R). Le résultat est très intéressant, très musical et très précis. L'image stéréophonique est bien plus claire. Aucune distorsion d'intermodulation. Bel équilibre spectral. Il faut au moins les alimenter avec une alimentation de 42 Volts DC pour avoir une puissance raisonnable sous 8 Ohms. Voilà. Bravo pour ce petit condensé technologique remarquable qui dépasse un Accuphase E305 appartenant à une autre génération. Prochaine étape : remplacer les AOP NE5532 par des Analog Devices ! (Tout à fait réalisable)
Rapport qualité prix impressionant
J'utilise 2 amplis A07 max en mode mono et c'est produit qui bien associé, c'est à dire avec un bon preampli peut se révéler très impressionant, car d'une très grande transparence.
En effet la puissance n'est pas un problème, mes Kef 105 -2 sont parfaitement tenues, cela descend bas, plus bas même qu'avec un ampli yamaha AS-2100. Impressionant ce que ces petites boites arrivent à envoyer comme jus, même si on reste tout de même loin des 300 W annoncés. Attention au voltage car les premières versions avaient des condensateurs de 50v un peu juste pour utiliser du 48v, pour ma part j'utilise l'alimentation 42v 8,5A Audiophonic sans probleme, cela chauffe tres peu. Je voulais tester la classe D à moindre frais je suis convaincu.
RECTIFICATIF....
Suite à mon premier avis (plutôt sévère) sur l'a07 MAX, j'ai le devoir de poster un nouvel avis, car après une soixantaine d'heures d'utilisation, mon A07 MAX a sensiblement évolué, preuve que le rodage des électroniques n'est pas une lubie d'audiophile mais un phénomène bien réel particulièrement en ce qui concerne les condensateurs de qualité. Il est vrai qu'à la sortie du carton ce petit ampli ne sonne pas bien avec des timbres acides et manquant de richesse, mais après un long rodage la restitution s'améliore: la transparence est excellente, supérieure à celle des A07 et A07 PLUS, ceci profite à l'image stereo qui se développe avec une grande aisance. Cette image sonore creusée dans le sens de la profondeur éloigne les protagonistes de plusieurs mètres, ainsi l'orchestre ne joue pas dans votre salon mais à 10 ou 15 mètres, sur la scène comme il se doit. On perd en proximité mais on gagne en réalisme. Du coup les voix, en particulier, semblent moins incarnées, bien que la richesse de timbre soit conservée. Ceux qui demanderaient plus de proximité et de présence pourront toujours intercaller entre leur source et l'ampli un petit préampli à tube qui redonnera de la rondeur et du soyeux. Les timbres sont honorables avec une belle instinction de notes et le respect des inflexions d'archet ou de voix, cependant une touche d'acidité persite encore dans le haut du spectre (à voir son évolution dans le temps...). En toute circonstance l'impact du grave est impressionnant et celui-ci reste d'une netteté exemplaire. Pour ceux qui voudraient tweaker leur A07 MAX sachez que les deux ampli ops sont remplaçables mais nécessitent un dessoudage des 4 câbles de sortie afin d'accéder à la carte. Personnellement les résultats les plus équilibrés à mes oreilles ont été obtenus avec des TLE2142CP alors q'avec les LM4562NA la restitution était trop brillante. Reste la grande inconnue de ce petit Aiyima: la fiabilité dans le temps, car ces petis équipement chinois peu coûteux ont trop souvent la fâcheuse tendance à une durée de vie restreinte.
DECEVANT...
Possesseur d'un Aiyima A07 et d'un "A07 PLUS", il faut reconnaitre que cet Aiyima A07 MAX est déroutant et décevant. Certes la transparence est très bonne mais les timbres sont monochromes, gris, sans saveur. Cordes acides et piano manquant singulièrement d'harmoniques. tweaké avec différents Ampli Ops (TLE2142 CP, 1612, ou LM4562), rien n'y fait! L'Aiyima A7 (simple) ou "l'A07 PLUS" équipés d'AOP LM4562NA font beaucoup mieux.
This small Class D Aiyima A07 MAX amplifier offers stereo as well as mono operation, so you...
