Ampli bon son avec très bonne dynamique.
Problèmes : écartement bornes hp pas normalisées.
diamètre passages de câbles hp très petits.
Bouton power on / off capricieux.
Ampli reçu pas neuf, modèle d'expo ?
Class D Amplifier TPA3255 2x220W 4Ω
The Aiyima A08 PRO is a small, very powerful, high-performance and affordable Class D amplifier. It is based on a TPA3255 amplifier chip and a NE5532P PDO, allowing it to deliver 2x220W of power into 4Ω, with a rich and dynamic sound reproduction. The front of the unit features a nice meter showing the output voltage on the speaker terminals, 2 bass / treble controls, as well as a large volume control. On the back there is a stereo RCA input, a Bluetooth antenna, as well as the speaker terminals and a 3.5mm jack line output for active speakers or subwoofers.
The design of the A08 PRO is also designed to match perfectly with the Aiyima T8 tube preamplifier, the latter is placed directly in the notch on the top of the case.
The Aiyima T8 preamplifier is sold separately.
Type of product | Amplifier |
Type of amplifier | Class D |
Amplification chip | TPA3255 |
OPA | NE5532P |
Bluetooth chip | QCC5125 |
Protocoles Bluetooth 5.0 | SBC / AAC / Apt-X / Apt-X HD / LDAC |
Inputs | 1x Stereo RCA 1x Bluetooth |
Ouputs | Speaker terminals 1x 3.5mm line level jack |
Power | 2x220W / 4 Ohm (@48V at 1% THD+N) 2x280W / 4 Ohm (@48V at 10% THD+N) 2x130W / 4 Ohm (@36V at 1% THD+N) 2x170W / 4 Ohm (@36V at 10% THD+N) |
Compatible speaker impedances | 4-8Ω |
SNR | ≥ 104dB |
Input sensitivity | 0.775V |
Frequency response | 20Hz-20kHz (±1dB) |
Power supply voltage | 24-48VDC (36V 6A power supply included) |
Dimensions | 152x123x40mm |
Color | Noir |
Net weight | 700g |
Input | Bluetooth |
Input | RCA |
Output | Jack 3.5mm |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 220.0 |
Remote Control | No |
Average votes 4.7 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Etienne c.
Etienne c.
david v.
jérome M.
