AIYIMA A09 5.1 Amplifier
The AIYIMA A09 is a 5.1-channel amplifier based on the use of various chips to process the signal. These include an AC6926A processor, MS8412 optical/SPDIF interface, NE5532 OPAs and several TPA3116D2 amplifier chips. This chipset offers an output power of 5x50W +50W to the AIYIMA A09, i.e. a substantial power reserve for sound reinforcement in any space.
Reference : 19815
134,90 €tax incl.
112,42 € tax excl.
Aiyima A09 Amplifier 5.1 Class D TPA3116D2 Bluetooth 5x50W+50W @ 4 ohm
AIYIMA A09 picture
The Aiyima A09 is a 5.1-channel amplifier based on the use of various chips to process the signal. These include an AC6926A processor, MS8412 optical/SPDIF interface, NE5532 OPAs and several TPA3116D2 amplifier chips. This chipset offers an output power of 5x50W +50W into 4 ohm to the Aiyima A09, i.e. a substantial power reserve for sound reinforcement in any space. On the interface side, it features analog RCA, optical toslink, SPDIF coaxial, USB-A (disk) and Bluetooth inputs, while on the output side, there are 6 speaker terminals, including one for passive subwoofer, as well as an output for active subwoofer. The front panel features volume control for each output channel, as well as bass and treble tone control. A number of buttons offer the following functions: previous, pause/play, next, and input selection. In short, this little amplifier is perfect for 2.1/5.1 multichannel amplification, or simply stereo, depending on your needs.
Please note that digital inputs do not support 5.1 configuration. Only analog inputs can output a 5.1 configuration. You'll need to pair the Aiyima A09 with several sources, a multichannel sound card or an AV processor to benefit quickly and easily from its 5.1 functionality.
Aiyima A09: a high-performance multi-channel amplifier
The Aiyima A09's 50W of power per channel offers a nice reserve of power. It also manages to maintain a low distortion level for clear, detailed overall sound reproduction.
AIYIMA A09 outputs
AIYIMA A09 Bluetooth functionality
Aiyima A09: Bluetooth functionality
The Aiyima A09 also supports Bluetooth functionality for fast use with a smartphone, for example. Bluetooth supports up to 16bit 44.1-48kHz.
Aiyima A09: dual power supplies
The Aiyima A09 has two separate power supply ports. It can automatically detect whether it is being powered by one or two ports simultaneously. Both power supplies must deliver the same voltage and current. The A09 is supplied with a 24V DC 8A power supply.
Dual power supply for AIYIMA A09
Aiyima A09 overview
AIYIMA A09 overview
1On/Off/Source selection button
2LED source indicators
3Previous/pause/play/next button
4Subwoofer volume
5Central volume
6Surround volume
7Front volume
8Overall volume
9Bass control
10Treble control
11USB-A input (Disk)
12Antenne Bluetooth
13Toslink optical input
14SPDIF coaxial input
15RCA 2.0 input
16RCA 5.1 input
17Passive subwoofer output
18Auxiliary power port
19Main power port
205.1-channel speaker terminal output
Product typeMultichannel amplifier
ChipsetAC6926A + MS8412 + NE5532 + TPS5430 + TPA3116D2
InputsBluetooth
1x Stereo RCA input
1x Optical Toslink
1x SPDIF Coaxial
1x RCA 5.1 input
Sortie6x Speaker terminals (2.0/2.1/5.1)
SNR≥ 100dB
THD0.05%
Bass and treble adjustment±6dB
Frequency response20Hz-20kHz (±1.5dB) and subwoofer 20Hz-120Hz
Output power5x50W + 50W @ 4 ohm
Supported sample ratesBluetooth : 16bit 44.1-48kHz
Optical Toslink/SPDIF Coaxial: up to 24bit 192kHz
Power supply15V-24V DC (24V DC 8A power supply included)
Dimensions130 x 231 x 49mm
Weight1.2kg
Package1x Aiyima A09
1x 24V 8A power supply
OutputSpeaker terminal
OutputSubwoofer
Channel2.1
Channel2 (Stereo)
Channel5.1
Amplifier chipTPA3116D2
Power (W)50.0
AIYIMA A09 Amplifier 5.1 Class D TPA3116D2 Bluetooth 5x50W+50W @ 4 ohm
The AIYIMA A09 is a 5.1-channel amplifier based on the use of various chips to process the signal. These include an AC6926A processor, MS8412...
