The Aiyima A70 Mono is a class D amplifier based on a circuit comprising a TPA3255 amplifier chip and a NE5532 OPA. It is capable of delivering power up to 300W into 4 ohm. Featuring PFFB circuitry for low distortion and noise reduction, the Aiyima A70 Mono amplifier's signal output is greatly enhanced. In terms of performance, it is capable of maintaining a THD+N of 0.0001% and offers an SNR ≥ 116dB. Moreover, Aiyima has chosen to offer it audiophile components such as Rubycon 63V 3300µF, Nichicon and Wima capacitors.
Regarding the A70 Mono's controls, there are two large potentiometers on the front panel, a switch for selecting its “sub” or “full frequencies” mode on the bottom panel and a +6dB RCA gain control on the rear panel. Its connectors include a mono RCA input and a balanced XLR/Jack 6.35mm combo input, while its output features a speaker terminal and a subwoofer output for an active subwoofer. The speaker terminal output can also feed a passive subwoofer or a passive loudspeaker. The set is completed by a 3.5mm jack 12V trigger input and a small potentiometer for subwoofer crossover frequency adjustment (40-200kHz).
Benefiting from a TPA3255+NE5532 chips combo with PFFB circuitry, the Aiyima A70 Mono delivers up to 300W into 4 ohm. All this while maintaining a THD+N of 0.0001% and an SNR of ≥ 116dB. Furthermore, as the NE5532 OPA is DIP8-mounted, it can easily be replaced by different models. Here is a non-exhaustive list of compatible OPAs: RT3609SM, OPA2604, OPA2134, LM4562, JRC5532, OP275GSZ, OPA1612, etc.
Rubycon 63V 3300µF filter capacitors
Large heat sink
WIMA capacitors
Nichicon audio capacitors
A selector switch allows you to choose the operating mode of the A70 MONO, depending on whether you wish to supply a passive subwoofer or a passive loudspeaker.
A large heat sink on the underside of the Aiyima A70 MONO, coupled with side vents, enables it to handle high power levels over long periods of time without overheating. It also provides effective protection for its internal components.
1 | Power LED indicator |
2 | Power switch |
3 | Passive subwoofer cutoff frequency setting |
4 | Volume control |
5 | RCA/XLR source selector |
6 | Input LED indicator |
7 | Balanced XLR/Jack 6.35mm combo input & RCA input |
8 | RCA gain +6dB |
9 | Active subwoofer LFE output |
10 | Active subwoofer cutoff frequency setting |
11 | 12V trigger input |
12 | Speaker terminal output |
13 | 24-48V DC power supply via DC jack |
" AIYIMA A70 MONO amplifier brings highly competent performance to the table with performance that beats majority of amplifiers I have tested. Yet it costs so little. Having balanced input, selectable gain for RCA and trigger are much appreciated... "
Product type | Mono amplifier |
Amplifier type | Class D |
Amplkification chip | TPA3255 |
OPA | NE5532 |
Inputs | 1x Mono RCA input 1x Balanced mono XLR/Jack 6.35 combo input |
Outputs | 1x Speaker terminal block 1x Subwoofer output |
Output power | 300W @ 4Ω (48V5A) |
SNR | ≥ 116 dB |
Distorsion | 0.001% |
Frequency response | 20Hz-20KHz (±0.5dB) |
Input sensitivity | RCA : Low gain 2Vrms (26dB) / high gain 1Vrms (32dB) XLR : 4Vrms (19dB) |
Output impedance | 2-8Ω |
Subwoofer output sensitivity | 2V |
Active subwoofer output cutoff frequency setting | 40-200Hz |
Alimentation | 24-48V DC via jack DC (48V 5A power supply included) |
Dimensions | 126.5 x 154.5 x 42mm |
Color | Black |
Weight | 900g |
Package | 1x Aiyima A70 Mono amplifier 1x 48V 5A power supply |
Input | RCA |
Input | XLR |
Input | Jack 6.35mm |
Output | Subwoofer |
Output | Speaker terminal |
Color | Black |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 300.0 |
Remote Control | No |
