Fonctionne très bien, simple et efficace.
Par contre il n'y a pas d'aigu c'est un peu frustrant...
Full Digital Amplifier FDA 2.1 TAS5624A Bluetooth 2x120w 4 Ohm
Aiyima's D03 is an FDA (Full Digital Amplifier) amplifier offering a nice energy reserve as well as a precise and transparent sound reproduction. It is indeed capable of developing no less than 2x120W under 4Ω (THD+N 1%) with a high efficiency, thanks to a TI TAS5624A amplifier chip. It also benefits from a particularly complete connectivity, with USB-B, Optical Toslink, Coaxial, stereo RCA (ADC PCM1808) as inputs, but also a Bluetooth 5.0 reception. Practical, this last one allows to diffuse remotely its music, from a smartphone, while taking advantage of the high resolution Bluetooth codecs aptX and aptX-HD. On the output side, there are of course speaker terminals but also an output for active subwoofer, on RCA connector.
Specifications | ||
Product type | Amplifier | |
Amplifier type | FDA | |
Output power | 2x120W @ 4Ω, 32V, 1% THD+N 2x60W @ 8Ω, 32V, 1% THD+N 2x140W @ 4Ω, 32V, 10% THD+N 2x75W @ 8Ω, 32V, 10% THD+N | |
Inputs | Bluetooth 5.0 1x USB-B 1x Optical Toslink 1x Coaxial 1x Stereo RCA | |
Outputs | Speaker terminals 1x RCA output for active subwoofer | |
Amplification chip | TAS5624A | |
ADC chip | PCM1808 | |
SPDIF Interfaces | CS8422 TAS5548 | |
Bluetooth chip | QCC3034 | |
Supported Bluetooth codecs | AAC, SBC, aptX, aptX-LL, aptX-HD | |
Supported sampling rates | PCM up to 24bit 192kHz | |
USB Compatibilité | Windows XP / 7 / 8 10 Mac OS Linux OTG smartphones | |
SNR | 93dB | |
Bass / Treble settings | ±14dB | |
Input sensitivity | 0.775V | |
Frequency response | 20Hz-20kHz (±1.25dB) | |
Subwoofer output level | 2.1V | |
THD | 0.001% (1kHz, 1W) | |
Speaker impedance | 4-8Ω |
Supply voltage | 24 - 36VDC on DC 5.5/2.5mm jack (32V 5A power supply included) |
Dimensions | 151 x 141 x 37mm |
Weight | 670g |
Housing material | Aluminum |
Package | 1x Aiyima D03 1x Power supply 1x Bluetooth antenna 1x Remote control 1x USB Cable 1x Optical cable |
Input | RCA |
Input | Optical |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Output | Subwoofer |
Output | Speaker terminal |
Color | Black |
Channel | 2.1 |
Class | FDA |
Amplifier chip | TAS5624 |
Power (W) | 120.0 |
Remote Control | Yes |
Average votes 4.8 / 5 12 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Alexandre W.
Eric z.
nicolas s.
Vincent S.
Philippe B.
