AIYIMA T9 PRO Amplifier TPA3250 Tubes 2x JAN5725 ES9018K2M Bluetooth aptX HD 2x60W 4 Ohm
7%
The Aiyima T9 Pro is a versatile and affordable integrated amplifier, ideal for setting up an audio system without breaking the bank or multiplying the number of devices. Its amplifier stage uses a TPA3250 chip associated with two JAN5725 tubes, allowing it to develop a power of 2x60W under 4Ω with the supplied 24VDC power supply.
4.3 / 5
Reduced price!
Reference : 17338
Limited time offer:
179,00 €tax incl.
-7%
166,47 €tax incl.
138,73 € tax excl.
Shipping date: 16-07-2025.
Aiyima T9 Pro
Amplifier TPA3250 2x JAN5725 ES9018K2M Bluetooth aptX HD 2*60W 4Ω
Aiyima T9 Pro Amplificateur TPA3250 2x JAN5725 ES9018K2M Bluetooth aptX HD 2*60W 4Ω
The Aiyima T9 Pro is a versatile and affordable integrated amplifier, ideal for setting up an audio system without breaking the bank or multiplying the number of devices. Its amplifier stage uses a TPA3250 chip associated with two JAN5725 tubes, allowing it to develop a power of 2x60W under 4Ω with the supplied 24VDC power supply or 2x100W under 4Ω with a 32VDC power supply (sold separately). It also embeds its own digital to analog conversion stage, using an ES9018K2M DAC chip, ensuring a quality decoding of the audio stream. But the great strength of the T9 Pro probably lies in its great versatility, which it owes to its complete connectivity. Indeed, we find in input USB-C, optical Toslink, coaxial, stereo RCA but also a wireless Bluetooth 5.0 connectivity with support for high resolution codecs aptX and aptX HD, allowing the distribution of its music from a smartphone for example.
T9 Pro
T9
Amplification chip
TPA3250
TPA3250
Output power
2*60W
2*60W
Supply voltage range
18-32VDC
18-30VDC
Tubes
JAN5725
6K4
Vumeters
Yes
Yes
Display
Yes
No
Bluetooth chip
QCC3031
AC6926A
DAC chip
ES9018K2M
MS8412
OPA
DSP chip
NE5532
MCU chip
NJW1194
AC6926A
USB interface
SA9123L (24bit 192kHz)
CM6542 (24bit 96kHz)
Product typeAmplifier
Amplification chipTPA3250
Tubes2* JAN5725
InputsBluetooth 5.0
1* Stereo RCA
1* USB-B
1* Optical Toslink
1* Coaxial
OutputsSpeaker terminals
1* Jack 3.5mm
Output power2*60W @ 4Ω, 24V, 1% THD
2*30 @ 8Ω, 24V, 1% THD
2*100W @ 4Ω, 32V, 1% THD
2*60W @ 8Ω, 32V, 1% THD
Bluetooth chipQCC3031
DAC chipESS ES9018K2M
USB interfaceSA9123L
OPAOPA1656
Volume controllerNJW1194
Supported sampling ratesPCM up to 24bit 192kHz
Supported Bluetooth codecsaptX, aptX HD
RCA output level2V
SNR≥ 102dB
Input sensitivity1.4V
Frequency response20Hz-20kHz (±1.5dB)
THD0.03% (1kHz, 1W)
Supply voltage18-32VDC 3A (24V power supply included)
Dimensions116*100*54mm
OutputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3250
Power (W)60.0
4 reviews
excellent ampli
possesseur d'un ampli creek evolution 100A , j'ai voulu tester la classe D
les tubes que l'on peut changer , le faible poids , le prix contenu , la taille réduite m'ont convaincu d'essayer cet appareil .
sans a priori , après quelques mois d'utilisation et d'écoutes alternées je peux dire que les 2 amplis se valent
à condition de changer les tubes d'origine .
la maitrise des enceintes est équivalente mais avec une ampleur sonore légèrement supérieure pour le T9 pro
sur mon modèle aucun problème avec les graves (bien maitrisés )
pour ce qui est de la puissance je suis entre 12 et 18 sur 100 de graduation ( lecture cd uniquement )
une écoute internet via pc m'obligerait surement même avec mon creek ( 110 watts /8 ohms ) à
monter le volume à 80% . si l'émission sonore est faible , il faut tirer sur l'ampli......
système utilisé : lecteur cd shanling , dac smsl en sortie coaxiale , ampli T9 pro , enceintes monitor audio 100 (rendement 87 db )
 (3)
This review has been posted for AIYIMA T9 PRO Amplifier TPA3250 Tubes 2x JAN5725 ES9018K2M Bluetooth aptX HD 2x60W 4 Ohm
PAS MAL ...MAIS PEU PUISSANT.
Restitution de bonne qualité avec une bonne définition et absence d'agressivité. Les basses manquent un peu de tension, cause probable d'une puissance trop modeste (il faut en effet régler le volume entre 75 et 90 sur une échelle de 100 pour avoir un niveau réaliste sur enceintes de bon rendement (90 db))
A Little Treasure
This little amp is cute and fun. It is very versatile and the Bluetooth works well. I have been using it as my television and CD/DVD/Blueray audio amplifier, and it has really grown on me. Whether the sound improved or I adjusted to it, I cannot say, but I really enjoy it. The power output is more than that of most of the amplifiers I've had in my life and the sound quality is surprisingly good. This little amplifier has an almost cult following in the U.S., and I can understand why. Small, convenient, multiple inputs, fun to look at and use, and it sounds good running my small and also cute speakers (Lii Audio Raindrop-3) and has the power to fill the house with music. Tiny and cute as it is, this is a serious little amplifier and I like it.
Du plaisir
le velouté des lampes au prix chinois...FDA chef d'orchestre, une discothèque toute numérisée sur PC, avec une baguette libre nommée foobar améliorée par une courbe cible du génial Pétoin drivant de petits large bande en caissons bass reflex triple ( en DIY merci Pétoin !!!!) et me voilà auditeur d'un chaîne HI-FI cheap mais très agréable.....je recommande fortement même si une sortie casque serait la bienvenue...
The Aiyima T9 Pro is a versatile and affordable integrated amplifier, ideal for setting up an audio system without breaking the bank or multiplying...
