DAYTON AUDIO DTA-100ST Class D Stereo Amplifier Bluetooth 5.0 2x35W 4Ω
The Dayton Audio DTA-100ST is a compact Class D stereo amplifier with an output power of 2x35W @ 4 ohm. It also features Bluetooth 5.0 functionality, allowing you to transmit your audio source remotely. It incorporates quality components such as a MA5332MS stereo amplifier chip. It also includes significant features such as an adjustable high-pass filter applied to its speaker terminal outputs.
Reference : 18357
219,00 €tax incl.
182,50 € tax excl.
Last items in stock !
Shipping date: 06-05-2025.
Class D Stereo Amplifier Bluetooth 5.0  2x 35W @ 4Ω
Dayton Audio DTA-100ST Class D Stereo Amplifier Bluetooth 5.0 2x 35W @ 4Ω
The Dayton Audio DTA-100ST is a compact Class D stereo amplifier with an output power of 2x35W under 4 ohm. It also features Bluetooth 5.0 functionality, allowing you to transmit your audio source remotely. It incorporates quality components such as a MA5332MS stereo amplifier chip. It also includes significant features such as an adjustable high-pass filter applied to its speaker terminal outputs. The DAT-100ST is designed to work in conjunction with the DTA-100LF, a low-frequency amplifier. In addition, the DTA-100ST features a pre-out output for chaining other Hi-Fi devices, and an AUTO-ON function that enables the DTA-100ST to switch off automatically after a certain period of inactivity. These features make the DTA-100ST an amplifier of choice.
A compact, elegant amplifier
Versatile and compact, the DTA-100ST can be used to power desktop speakers or as part of a complete Hi-Fi installation. It delivers quality sound reproduction while keeping a small size. Its aluminum case features high-quality knobs and potentiometers on the front and rear panels.
DTA-100ST: great audio performance
With its 2x35Wrms under 4 ohms, it delivers a respectable power level, while maintaining a clean sound with low distortion. Its frequency response from 20Hz to 20kHz will fill your space with a wide range of sonorities.
Unique features
As previously mentioned, the DTA-100ST features a high-pass filter adjustable from 20Hz to 250Hz, operating on the speaker terminals. This filters high frequencies, enabling the DTA-100ST to be coupled with the DTA-100LF low-frequency amplifier. A preamplifier output also enables you to chain other Hi-Fi devices, and an AUTO-ON mode enables it to switch off automatically after 15 minutes of inactivity.
Mounting brackets included
A mounting bracket is included with the DTA-100ST. It consists of two aluminum mounting plates. These allow the DTA-100ST to be mounted on or under a shelf or a desk, for example.
Product typeAmplifier
Amplification typeClass D
Output power2x 35Wrms @ 4Ω
Total gain27.5dB
THD+N< 0.06%
Frequency response20Hz-20kHz
Input sensitivity215mV
Channel separation70dB
Minimum speakers impedance4Ω
SNR101dB
Bluetooth5.0
Power supply100-240V 50/60Hz
Standby power consumption2W
Dimensions 190 x 50 x 139mm
Weight1.26kg
Package1x Dayton Audio DTA-100ST
1x Mounting brackets
1x Power supply cable
1x Power supply adapter
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipInfineon MA5332M
Power (W)35.0
The Dayton Audio DTA-100ST is a compact Class D stereo amplifier with an output power of 2x35W @ 4...
