DAYTON AUDIO HTA100BT Hybrid Tube Amplifier BT5.0 Phono 2x50W / 4 Ohm
The HTA100BT stereo amplifier provides the roundness and richness of tube amplifiers while taking advantage of a completely up-to-date connection including no less than a USB, Bluetooth 5 and SPDIF input but also AUX and phono inputs to be fully prepared for all home integration scenarios.
4.7 / 5
Reference : 15013
299,00 €tax incl.
249,17 € tax excl.
Warning, before connecting this amplifier you must position the power selector in accordance with your electrical network (220V or 110V).
Dayton Audio HTA100BT
Hybrid Tube & Class AB Stereo Amplifier / Phono, USB, SPDIF, Bluetooth 5
Dayton Audio HTA100BT amplificateur tube entrée phono
The HTA100BT is a stereo integrated amplifier remarkable for its hybrid construction. It indeed embeds a power amplification stage operating in class AB as well as a tube pre-amplification stage. A rare design that borrows from contemporary amplification technologies while retaining the typical warm tones of tube circuits to rediscover all the pleasure of these sounds in a modern environment that is easy to connect to a recent High-Fidelity installation.
Ergonomics and design
A beautiful retro design with surface mounted tubes and front level vumeters, as well as a solid aluminum housing make the HTA100BT a device with a distinct visual character that is sure to add some style to your audio installation.
Its front interface brings together a plethora of options to make it easier to use while skilfully playing on the contrast of the different elements in order to remain readable and easy to handle. In addition to the two vumeters dedicated to each channels of the stereo signal, there is an ON / OFF button, a diode display of the active source, a source selector button, two rotary potentiometers dedicated to the bass / treble equalization as well as a third larger potentiometer intended to control the volume.
Finally, three discreet buttons allow you to directly control playback from the front of the HTA100BT (play / pause - next track / previous track).
Power and flexibility
With an output power of 50 watts per channel under a load of 4 ohms, the HTA100BT offers ideal power reserve for the needs of almost any home audio listening system.
In addition to the regular connectivity of a modern integrated amplifier (Coaxial SPDIF, Optical) which can connect the device to all of your digital sources (DAC, television, game console, etc.), the HTA100BT benefits from broad connectivity designed to dramatically simplify the lives of audiophiles equiped with devices using different technologies.
Bluetooth 5 (SBC & AAC) compatibility allows high quality wireless streaming that is easy to set up with the most common wireless audio sources (smartphone, tablet, laptop, streamer).
A dedicated phono input allows a vinyl turntable to be directly connected to the HTA100BT which will process the analog signal directly through its tube preamplifier.
Finally, a USB input allows you to play FLAC, MP3, WMA, WAV, and APE audio files stored on an external device such as a hard drive or a USB pen drive.
On the output side, in addition to speaker terminals dedicated to its amplified output, the HTA100BT has a summed line output, very practical for connecting an active subwoofer and obtaining a complete 2.1 system. The latter is directly connected to the output of the preamplification stage.
TypeIntegrated amplifier
Power2x 50W RMS under 4 Ohms
THD0.5% @ 2x50W
Speaker minimal impedance4 Ohms
Crosstalk50dB
SNR≥ 80dB
Frequency response20-20,000 Hz
Sub outPreout not filtered
Tubes6U1 x 2, 6F2 x 2
TransistorsToshiba A1941 x 2, Toshiba C5198 x 2
BluetoothV5 support SBC and AAC
File readerFLAC, WAV, APE, WMA, MP3
DAC SNR96 dB
DAC sampling rateUp to 16-bit/48kHz
Input impedance47 kohms (minimum)
Input sensitivity350 mV
Power110/220V, 50/60 Hz
IEC socket
Dimensions6.6" x 11.5" x 10.6"
167 x 292 x 269 mm
Weight6,3kg
InputPhono
OutputSpeaker terminal
OutputSubwoofer
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTube
Power (W)100.0
3 reviews
VVHP
Matériel et livraison impeccables.
Attention : matériel livré réglé en 110V...
This review has been posted for DAYTON AUDIO HTA100BT Hybrid Tube Amplifier BT5.0 Phono 2x50W / 4 Ohm
Une belle surprise
J'ai beaucoup hésité à acheter cet ampli. Mon précédent appareil dont j'étais si satisfaite, je cherchait quelque chose de joli, qui sonne bien avec des connectiques diverses. Ce petit Dayton Audio cochait toutes les cases : design rétro comme j'aime avec le préampli à lampe, un encombrement optimal, une entrée phono, une optique, une RCA et une connexion Bluetooth. Tout cela pour moins de 300 euros… J'ai cherché des avis mais n'en ai trouvé que sur Amazon.uk et le produit n'était plus disponible. Les avis étaient plutôt positifs. Grâce au retour possible sous 14 jours du site Audiophonics, je me suis laissée tenter.
Le suspens était à son comble : 30 jours pour un réapprovisionnement de l'article mais le service client du site est actif et réactif, ce qui m'a rassurée.
Le colis arrive enfin en parfait état (merci au transporteur). Je l'ouvre : connectique anglaise ! Encore un peu d'attente pour le brancher avec un shuko.
Première écoute : plutôt pas mal pour le prix ! J'ai entendu mieux mais super dynamique sur les enceintes Sony vintage APM22ES. Des aigus plutôt clairs et timbrés. Il manque un peu de détail dans les médiums. Les basses sont rondes et dynamiques. La couleur est assez chaude grâce à la pré amplification à lampe. L'ensemble est vraiment bien pour ce prix et mon ensemble est un régal pour les yeux. Du coup, j'ai branché ma Technics MK2, ma box internet en optique (associée à mon vidéoprojecteur pour l'image, c'est du bonheur sans problème de latence), ma platine CD en RCA et le gros plus : la connexion Bluetooth est parfaite et Deezer sur mon téléphone tourne en continu avec un son assez bluffant.
Les petits bémols (oui, ii y en a mais ils sont anecdotiques) : Pas de télécommande : il ne faut pas avoir des problèmes de dos s'il est installé près du sol. Une fois le canal sélectionné, l'ampli se reconnecte au Bluetooth de l'appareil appairé systématiquement une fois donc il faut resélectionner le canal initial. Le sélecteur de canal sur la face avant est blanc froid alors que les lampes et les vu-mètres sont jaunes.
En conclusion : très belle surprise auditive et esthétique pour cet achat au prix raisonnable eu égard aux diverses connectiques et à la bonne qualité sonore.
Excellent petit couteau suisse de la Hifi
J'ai fait acheter ce petit ampli à un ami et franchement , et franchement pour le prix, c'est vraiment super.
Il est beau, avec une finition irréprochable et surtout, il sait tout faire.
Le son est plus que correct et n'oublions pas qu'il vaut 239 €...c'est le prix d'une poignée de main dans un magasin de HIFI Hight End.
 (7)
The HTA100BT stereo amplifier provides the roundness and richness of tube amplifiers while taking advantage of a completely up-to-date...
