FOSI AUDIO BT30D PRO Class D 2.1 Amplifier 2xTPA3255 Bluetooth 5.0 2x125W+250W 4 Ohm
The Fosi Audio DT30D Pro is a small, powerful and affordable Class D amplifier, ideal for the integration of a simple but powerful audio system. It embeds for that two TPA3255 amplification chips allowing him to develop a comfortable power of 2x 125W under 4Ω with a high efficiency proper to the Class D architectures...
3.3 / 5
Reference : 17206
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 15-05-2026.
Fosi Audio BT30D Pro
Amplificateur Class D 2.1 2x TPA3255 Bluetooth 5.0 2x125W + 250W 4Ω
The Fosi Audio DT30D Pro is a small, powerful and affordable Class D amplifier, ideal for the integration of a simple but powerful audio system. It embeds for that two TPA3255 amplification chips allowing him to develop a comfortable power of 2x 125W under 4Ω with a high efficiency proper to the Class D architectures. To that, the DT30D Pro adds a subwoofer output providing it 250W, allowing the use of a subwoofer for deeper bass. The amplifier also features a tone control that allows you to adjust the bass, treble, subwoofer and crossover frequency independently. It can therefore be easily adapted to any audio distribution system.
On the connectivity side, once again, the DT30D Pro aims at simplicity and efficiency. The outputs are on speaker terminals or via a pre-out output in 3.5mm jack format. For the inputs, the DT30D Pro offers stereo RCA but also Bluetooth 5.0. It is therefore possible to broadcast and control your music remotely, from a smartphone or a tablet for example.
Product typeAmplifier
InputsBluetooth 5.0
1* Stereo RCA line input
OutputsSpeaker terminals
Subwoofer output on speaker terminals
1* Pre-Out on Jack 3.5mm
Amplification chip2*TPA3255
Output power2 * 125W + 250W @ 4Ω, 1% THD / 36V DC
2 * 160W + 300W @ 4Ω, 10% THD / 36V DC
THD≤ 0.03%
SNR108dB
Subwoofer frequency cut-off20-300Hz
Supply voltage12-36VDC (32VDC power supply included)
Package1* Fosi Audio BT30D Pro
1* Power supply 32VDC 5A
1* Bluetooth antenna
OutputSpeaker terminal
OutputSubwoofer
OutputJack 3.5mm
Channel2.1
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)125.0
3 reviews
Acheté pour mon son tv pour y ajouter un caisson passif.
Le réglage indépendant du caisson est très pratique.
Son un peu plat il faudra lui ajouter un dac gagner en clarté surtout pour les voix.
Les aigus même tournés à fond cela ne suffit pas.
This review has been posted for FOSI AUDIO BT30D PRO Class D 2.1 Amplifier 2xTPA3255 Bluetooth 5.0 2x125W+250W 4 Ohm
Bon produit
Pour le prix est vraiment un bon produit .
DECEPTION
J'ai comparé ce petit Fosi Audio BT30 D Pro à mon Aiyima A07 modifié et à ma surprise, le Fosi ne tient pas la comparaison. La définition est certes bonne mais les timbres sont un peu sommaires (sensible sur du piano) et l'image stereo pourrait être plus profonde et plus transparente. L'amélioration de ce Fosi Audio est quasi impossible car les AOP sont soudés sur la carte et non sur support, véritable erreur de la part du concepteur! Mon Aiyima monté avec AOP TLE2142 CP fait mieux sur tous les critères ci-avant énoncés.
The Fosi Audio DT30D Pro is a small, powerful and affordable Class D amplifier, ideal for the integration of a simple but powerful audio system. It...
