Hybrid Amplifier 6N1 Tubes WiFi Bluetooth 4.0 2x50W 4 Ohm
McGee offers with the Harmony a high-performance hybrid amplifier, using both two 6N1 tubes for the preamplifier stage, ensuring a natural and warm sound, associated with transistors for the amplifier section, providing a power of 2x50W under 4Ω. Complete, the Harmony has wireless connectivity in Bluetooth 4.0 for broadcasting in particular from a smartphone, or WiFi to access files stored on your local network. The amplifier is also not stingy when it comes to connectivity, and offers stereo RCA, optical and coaxial inputs. On the output side, there are speaker terminals, but also stereo RCA (pre-out) and a 12VDC trigger output on 3.5mm jack.
Product type | Amplifier |
Inputs | 1x Stereo RCA WiFi IEEE 802.11 b/g Bluetooth 4.0 1x Coaxial 1x Optical Toslink |
Outputs | 1x Stereo RCA Pre-Out Speaker terminals 1x 12VDC Trigger output |
Output power | 2x50W |
Frequency response | 20Hz - 60kHz (±0.5dB) |
Input sensitivity | 250mV |
SNR | > 90dB |
Input impedance | 47kOhm |
Supported file formats | WAV, FLAC, APE, LPCM, MP3, AAC, AC3, WMA |
Streaming services and protocols (via Wiim application | DLNA, AirPlay, Spotify, Tidal, Qobuz, Deezer, Amazon Music, Napster, Web Radios |
Supply voltage | 230VAC 50Hz |
Consumption | 29.8W |
Dimensions | 360 x 300 x 70mm |
Weight | 6.8kg |
Color | Black |
Housing material | Aluminum |
Package | 1x McGee Harmony 1x Power cable 1x Bluetooth antenna 1x WiFi antenna 1x Remote control 1x Optical cable |
Input | WiFi |
Input | SPDIF |
Input | Bluetooth |
Input | RCA |
Input | Optical |
Output | Speaker terminal |
Output | RCA |
Color | Black |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 50.0 |
Remote Control | Yes |
