SABAJ A30A FDA Amplifier 2x STA516BE AX5689 Bluetooth aptX HD LDAC 2x200W 4 Ohm
10%
Sabaj unveils with the A30a a beautiful Class D integrated amplifier, capable of delivering great power while offering a rich and precise reproduction. Its connectivity makes it extremely versatile, covering most uses for easy integration into most audio systems.
3.0 / 5
Reduced price!
Reference : 16692
Limited time offer:
629,00 €tax incl.
-10%
566,10 €tax incl.
471,75 € tax excl.
Last items in stock !
Shipping date: 01-07-2025.
Sabaj A30a
Sabaj A30a Amplificateur Class D 2x STA516BE AX5689 Bluetooth aptX HD LDAC 2x200W 4 Ohm
High-end design
In order to provide a superb sound reproduction, the Sabaj A30a is based on a careful architecture, integrating quality components, intelligently selected. Thus, we find in its heart two STA516BE amplifier chips, one per channel, associated with an Axign AX5689 control chip, allowing to deliver with great efficiency a power of 2x200W under 4Ω.
The power supply stage also benefits from the same care as the other circuits, with an independent power supply for the power stage and a filtering system to effectively reduce noise and distortion.
XMOS XU208 USB Interface
The A30a's USB-C input is paired with a second generation XMOS XU208 8-core interface. Thus, Sabaj's amplifier is capable of playing high-resolution audio streams via this input, up to PCM 32bit 768kHz and DSD512.
Connectivity & Bluetooth 5.0
Le Sabaj A30a propose une connectique complète, avec en entrée de l'USB-C, du coaxial, de l'optique Toslink et du RCA stéréo. Il ajoute en plus une capacité de réception Bluetooth, permettant de diffuser sa musique à distance, depuis un smartphone par exemple. Cette dernière supporte qui plus est les protocoles de transmission aptX HD et LDAC, permettant une reproduction sonore de qualité en sans-fil.
Subwoofer output
The Sabaj A30a also provides a subwoofer output on RCA connector. This will allow you to equip your audio system with a subwoofer, for deep and punchy bass.
1Screen
2Multifunction button
3Powre input
4Right channel speaker output
5Left channel speaker output
6Bluetooth antenna
7USB-C input
8Optical input
9Subwoofer output
10Coaxial input
11RCA input
Product typeAmplifier
Amplification typeClass D
InputsBluetooth 5.0
1x USB-C
1x Optical Toslink
1x Coaxial
1x Stereo RCA
OutputsSpeaker terminals
1x Subwoofer output
Output power2x200W @ 4Ω
2x100W @ 8Ω
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
THD+N0.008%
SNR116dB
Channels separation108dB
Subwoofer output level2Vrms
Subwoofer output cutoff frequency70Hz - 160Hz @ -3dB
USB Transmission modeAsynchrone
USB CompatibilitéWindows 7 / 8 / 8.1 / 10
Mac OS X 10.6 or later
Linux
Supply voltage110-240V
Consumption< 0.5W
Dimensions280 x 260 x 63mm
Weight3.3kg
ColorSilver
Package1x A30A
1x Power cable
1x Bluetooth antenna
1x USB-A to USB-C cable
1x Remote control
OutputSubwoofer
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
Channel2.1
ClassFDA
Amplifier chipSTA516B
Power (W)200.0
Remote ControlYes
2 reviews
Cata en 2.1 - chauffe et se met en protection
Le son est très bon. J'en suis tout surpris venant du monde de l'analogique.
Sur le site audiosciencereview, un défaut est mis en avant et il n'est pas des moindres.
Si l'on branche un caisson de basses actif (c'est mon cas), ce dernier crachouille (bruit blanc + toc toc) et ça ... c'est pas possible. Surtout en absence de musique, le caisson bruite la pièce.
Ensuite, sur mes enceintes difficiles (Martin Logan), le Sabaj chauffe et se met en protection. Assez rapidement. Le volume va à 99, dès 80, ça coupe et franchement le niveau n'est pas si fort que ça.
Le SMSL A300, juste ampli, va beaucoup plus loin en puissance sans disjoncter.
Donc, une machine très bien pour des enceintes à bon rendement et sans utilisation de caisson.
Pas d'appli smartphone de prévu pour piloter du canapé.
Il faudra vous équiper d'une longue vue.
This review has been posted for SABAJ A30A FDA Amplifier 2x STA516BE AX5689 Bluetooth aptX HD LDAC 2x200W 4 Ohm
une écoute "classe A"
L'écoute de cet appareil, ainsi d'ailleurs que sa construction, m'a de suite fait penser à un excellent ampli de classe A (Krell...) Stabilité, neutralité, douceur et fermeté, spatialisation...tout y est ! Le prix peut sembler élevé, mais je considère que cet ampli peut rivaliser avec les meilleures réalisations "traditionnelles"... magnifique !
Sabaj unveils with the A30a a beautiful Class D integrated amplifier, capable of delivering great power while offering a rich and precise...
