No featrued products
The SMSL AO10 is a Class D stereo amplifier equipped with two Texas Instruments TPA3116 chips, delivering 2x70W into 4Ω. It features Bluetooth 5.3 connectivity with support for SBC and AAC codecs for wireless use, as well as a 12V trigger input and output system for optimal integration into your HiFi system.
The AO10 is based on a Class D amplification architecture with dual TPA3116 chips. This configuration delivers 2x70W of power into 4Ω, or 2x100W into 2Ω. An electronic volume control replaces the traditional mechanical potentiometer, eliminating contact noise and ensuring channel balance across the entire attenuation range.
The AO10 features a Bluetooth 5.3 receiver chip and supports AAC and SBC codecs. This allows you to easily enjoy audio sources such as your smartphone for remote use. In addition, for optimal ease of use, the AO10 includes a 12V trigger input and output, allowing you to synchronise it with the rest of your audio system.
| Specifications | |
| Product type | Integrated amplifier |
| Inputs | 1x Stereo RCA Bluetooth |
| Output | Speaker terminals |
| Frequency response | 20Hz-20kHz |
| Bass and treble adjustment range | -10dB ~ +10dB |
| Total harmonic distortion more noise (THD+N) | 0.02% |
| Channel separation | -103dB |
| Input sensitivity | 500mVrms |
| Output power | 2x100W @ 2Ω 2x70W @ 4Ω |
| General | |
| Power supply voltage | 100-240V AC |
| Consumption | 36W |
| Dimensions | 190.4 x 46 x 163.2mm |
| Weight | 840g |
| Package | 1x SMSL AO10 1x Remote control 1x Power cable 1x 3.5mm jack cable, 1m |
| Input | Bluetooth |
| Input | RCA |
| Output | Speaker terminal |
| Color | Black |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | TPA3116 |
| Power (W) | 70.0 |
| Remote Control | Yes |
