SMSL AO200 MKII Class D Balanced Amplifier MA5332MS Bluetooth 5.0 Subwoofer 2x160W 4 Ohm
The SMSL AO200 MKII is a compact and powerful Class D digital amplifier, capable of developing a power of 2x160W under 4Ω thanks to its Infineon MA5332MS amplifier chip. A power totally mastered in order to reveal a sound restitution of a great purity and dynamics.
Reference : 18050
219,00 €tax incl.
182,50 € tax excl.
Shipping date: 10-04-2026.
SMSL AO200 MKII
SMSL AO200 MKII Amplificateur Class D 2x MA5332MS Symétrique Bluetooth 5.0 Subwoofer 2x160W 4 Ohm
The SMSL AO200 MKII is a compact, high-performance Class D digital amplifier capable of developing 2x160W of power at 4Ω, thanks to its Infineon MA5332MS amplifier chip. Power that's totally controlled to reveal a sound reproduction of great purity and dynamics. Versatile, it boasts not only a balanced input, but also Bluetooth 5.0 reception and a subwoofer output.
Balanced and unbalanced
The SMSL AO200 MKII is equipped with two inputs, so it can be integrated into any audio system and adapted to every need. There's an unbalanced RCA input and a balanced XLR input. Each connector is gold-plated for excellent conductivity and durability.
Subwoofer output
With the AO200 MKII, you can set up a 2.1 audio system, thanks to an RCA connector output. Ideal for achieving ever deeper, punchier bass.
Infineon MA5332MS
At the heart of the AO200 MKII's amplification stage lies an Infineon MA5332MS Class D amplifier chip. It delivers substantial power, combined with high efficiency (95%), low power consumption and rich sound. This chip adopts an MCM (Multi-Chip Module) solution with a 2-channel PWM controller and 4 Mosfet transistors.
Bluetooth 5.0
With its Bluetooth 5.0 receiver, the AO200 MKII lets you broadcast your music remotely, directly from a smartphone for example. The 5.0 standard ensures fast, stable transmission over a distance of 10m.
Equalizers
The AO200 MKII incorporates 8 preset equalizers, to adapt to your listening style and audio system. You can also manually adjust the bass and treble levels for fine-tuning.
SMSL AO200 Class D Amplifier MA5332MS Balanced Bluetooth 5.0 Subwoofer 2x160W 4 Ohm
High-end components
The AO200 MKII's circuitry uses high-quality components to deliver the best possible performance. These include a particularly precise, low-distortion NJW1194 volume controller, OPA1678 AOPs, ERO capacitors and low-noise MELF resistors.
Optimized power supply stage
The power supply is based on a custom-designed power module delivering an instantaneous power of 300W. The result is a dynamic output that effectively limits the impact of interference. To achieve this, it uses a large, low-leakage transformer and two-stage input filtering.
1Multifunction knob
2Display
3Balanced XLR input
4Unbalanced RCA output
5Subwoofer output
6USB-A input
7Bluetooth antenna connector
8Right channel speaker terminal
9Left channel speaker terminal
10IEC power supply input
11Power switch
Product typeAmplifier
Amplification chipInfineon MA5332MS
Inputs1* XLR stereo balanced
1* RCA stereo unbalanced
Bluetooth 5.0
1* USB-A
OutputsSpeaker terminals
1* Subwoofer (RCA)
THD+N0.004%
SNR106dB
Channel separation85dB
Input sensitivity290mV
Input impedance47kΩ
Output power2x 160W @ 4Ω
2x 85W @ 8
Power supply110-240VAC
Power consumptionNormal volume level: 40W
Standby: 0.5W
Dimensions210*194*41mm
Weight1.6kg
Package1* SMSL AO200 MKII
1* Power cable
1* Bluetooth antenna
1* USB cable
1* Remote control
InputXLR
OutputSubwoofer
OutputSpeaker terminal
Channel2 (Stereo)
Channel2.1
Amplifier chipInfineon MA5332M
Power (W)160.0
Remote ControlYes
8 reviews
Surprenant...
Pour un tarif très abordable, on dispose d,un ampli puissant, transparent et dynamique
A utiliser avec une source analogique sur rca ou xlr,l'entrée usb est par contre médiocre...
Mes petites colonne à base de Audax font enfin du grave profond et précis
Les voies sont magnifiques
Attention, sonorité type claire
En tout cas ,bien meilleur à mes oreilles que mon ex cambridge axa 35 valant bien plus cher
This review has been posted for SMSL AO200 MKII Class D Balanced Amplifier MA5332MS Bluetooth 5.0 Subwoofer 2x160W 4 Ohm
Impressions après 1 mois d'utilisation
Après un mois d'utilisation quasi quotidienne (couplé à un Eversolo DMP-A6 d'abord en RCA puis en XLR): Les 2 connectiques sont excellentes, même si en XLR on gagne encore en ampleur et dynamique, la différence est clairement audible.
Comme les entrées RCA et XLR sont sélectionnables indépendamment, j'ai donc branché la sortie RCA de ma télé au SMSL, pour m'affranchir d'une barre de son plus que moyenne. (La consommation électrique doit être identique, par contre on gagne en qualité audio!)
Quant au réglage EQ initial (j'adorais le SDB au début) je suis finalement revenu en mode Direct ou Tone (Bass +1, Treble +2) selon ce que j'écoute, pour atténuer les basses du SDB, qui n'étaient pas si présentes au début. Un petit rôdage des composants a fini par assoir l'accoustique de cet ampli, en améliorant le mode direct.
L'entrée audio USB testée depuis le DMP-A6 (qui a une sortie usb audio out only) ne donne que du 16 bits/48KHz, (Test avec un fichier FLAC 32/384, j'ignore si c'est le Eversolo ou l'ampli SMSL qui est bridé...). Dommage, je reste donc en XLR. N'espérez pas non plus y brancher un lecteur CD usb ni votre smartphone. Rien n'est détecté, Ce n'est qu'une prise audio IN de plus, pour peu qu'on ait le lecteur disposant de la même prise usb audio out only, sinon elle est inutile, mais elle chargera quand même votre téléphone. (lentement....)
En fin de compte je l'aime toujours autant ce SMSL AO200 MKII, même s'il ne lui manque qu'une ou 2 entrées digitales pour être vraiment parfait. :)
Accord parfait
Je ne trouve pas de mot plus approprié que "parfait". Cet ampli est le parfait mariage avec mes Tannoy System 800 (monitor). Le son est chaleureux, détaillé, la scène est ample, remplit tout l'espace. Ce son me plait beaucoup, je verrai à l'usage s'il s'améliore après quelques heures de rôdage.. Je destinais initialement l'ampli à mes Tannoy Mercury V1i (bibliothèque), pour remplacer un vieil Alientek D8 dans la chambre, qui donne pourtant toujours un effet WOW sur des pistes haute définition et bien mixées (couplé à un DAC Topping D50), mais après avoir testé l'ampli en XLR sur un Eversolo DMP-A6, d'abord sur les monitor 800, puis sur les V1i, je dois avouer que les 800 sortent gagnantes, le son est ample, enveloppant, chaque instrument à sa place selon le mixage initial de la musique. L'ampli SMSL AO200 MKII est très transparent, surtout en mode SDB sur l'égaliseur, il reproduit le son tel qu'il le reçoit. Pour le prix, n'hésitez pas, si comme moi vous aviez un petit ampli qui rendait déjà service (type Alientek ou Topping) et qu vous voulez un son qui monte en gamme, sans se ruiner, c'est l'ampli parfait! Les gros + : entrée USB, les entrées XLR, l'entrée bluetooth (quand on a un vieux DAC non équipé), les 2 sorties subwoofer, le réglage EQ maison SDB. Les petits - : pas de auto On/auto Off comme sur l'alientek (bien pratique pour que l'ampli se mette sous tension à la détection d'un signal audio) et pas de prise casque (mais je ne le destinais pas à un casque). Bref très content de cet achat, merci Audiophonics pour la rapidité du traitement de la commande!
 (3)
excellent ampli
Disposant d’un DAC SMSL SU8 avec sorties symétriques, j’avais envie d’avoir un ampli avec entrées XLR, d’autant que je suis très sensible à la qualité des silences dans une installation hifi. Jusqu’alors satisfait de mon ampli BC ACOUSTIQUE 222.3, j’ai tout de même décidé de passer à cette classe D économe en énergie et donc écolo, compacte, au design sympa mais en ayant des doutes quant à sa musicalité (appelons ainsi la capacité d’un appareil à restituer la musique le plus naturellement possible ou du moins dans des conditions qui font que l’écoute se fait oublier). Je me doutais que la restitution serait dynamique car même nos petits autoradios ou nos télés (la plupart amplifiées avec des modules classe D basiques) ont de la pêche et que les basses seraient toniques. Simple confirmation de ce côté, mais quid du reste ? Eh bien, c’est avant tout plein de détails. Là, entre mon ancien ampli et le nouveau, il n’y a pas photo. Côté bruit de fond, c’est très bon, les pianissimi et nuances fines ressortent bien. Les timbres, eux, sont bons sans être exceptionnels, ça s’entend sur des violons par exemple, il reste une petite touche pas nécessairement électronique mais pas totalement naturelle, c’est très léger et parfois on se demande très sérieusement si ce n’est pas plutôt la prise de son qui est en question. L’autre très léger regret, c’est parfois une impression de manque de corps mais là encore, c’est subtil et difficile à décrire, il est très possible que ce soit simplement la différence entre une restitution « à l’ancienne » (j’ai biberonné aux vieux amplis analogiques) et une restitution plus objective, plus droite, plus fouillée. Côté image, je ne m’avance pas car mon installation dans une salle à manger avec la table devant les enceintes n’est vraiment pas idéale !
Au final, très satisfait de mon achat même si côté équipement ma migration a nécessité que j'achète un ampli casque dédié à brancher sur la sortie asymétrique de mon DAC : la restitution est dynamique, bourrée de détails et vivante. Sur de la musique actuelle, ça le fait totalement. Sur de la musique classique, ses nombreuses qualités suffisent à emporter l’adhésion mais il reste une petite matité dans les timbres à peaufiner. Reste à voir comment se comportera l’appareil sur la durée (mais mon dac de la même marque, datant de quelques années, est toujours aussi vaillant...)
30 ans de certitudes audiophiles balayées en quelques secondes
Allez, je commence par 2 points négatifs : Le bluetooth est mauvais et les borniers HP n'acceptent pas les cables de grosse section avec fourches. Dommage, car cet ampli a des performances incroyables. Connecté à un streamer Aurender et un DAC Denafrips Pontus II en XLR, Il alimente à merveille mes capricieuses Thiel 2.4. Le registre grave est sublimé. Quelle énergie, présence et tenue ! L'aigu est fin et précis, la transparence est incroyable.Une prouesse à ce prix, et même bien au delà. J'ai possédé de nombreux amplis plus "ésotériques".. et beaucoup, beaucoup plus chers qui ne tiennent pas la comparaison (surtout dans le grave).La profondeur et la largeur de la scène sonore ne rivalisent pas encore avec des amplis HDG à x milliers d'Euros mais on parle ici d'un ampli à 249€ ! Mais commant font-ils chez SMSL ? La classe D a fait d'énormes progrès et ça s'entend clairement. ça donne envie de tester des modèles plus haut de gamme, Certaines marques "audiophiles " bien établies ont du soucis à se faire....
Et toujours une livraison ultra rapide de la part d'Audiophonics !
 (3)
The SMSL AO200 MKII is a compact and powerful Class D digital amplifier, capable of developing a power of 2x160W under 4Ω thanks to its...
