By buying this product you get 27 loyalty points
The SMSL AS400 is an extremely versatile integrated amplifier. It offers numerous advantages, such as a phono input, an HDMI ARC input, a preamplified output for active subwoofers, and two headphone outputs. It also features an audiophile chipset consisting of a CS43131 DAC chip coupled with an XMOS XU-316 USB interface, an MA5332MS amplifier chip, and an NJW1194A volume control chip. This allows it to support sampling rates up to PCM 32-bit 768kHz and DSD256 while delivering up to 2x 165W of power under a 4-ohm load via its speaker terminals. On top of that, it features Bluetooth with support for high-res aptX-HD and LDAC codecs for reliable and stable wireless transmission. On the front panel, there's also a nice display that shows info about what's playing, and you can control the AS400 intuitively and conveniently with an IR remote. In terms of connectivity, as mentioned above, the AS400 has numerous inputs and outputs, allowing you to enjoy a 2.1-channel system or listen with headphones.
The SMSL AS400 combines a DAC chip and XMOS XU-316 USB interface to support sampling rates of up to 32-bit 768 kHz and DSD256, allowing you to enjoy high-definition files on streaming platforms or locally. The MA5332MS amplifier chip delivers up to 2x 165W of power at 4 ohms and 2x 85W at 8 ohms with a THD+N of only 0.003% for clean sound in small to medium-sized spaces.
The SMSL AS400 features a Bluetooth input that supports high-definition SBC, AAC, aptX-HD, and LDAC codecs for reliable and stable wireless transmission. This allows you to quickly enjoy various streaming platforms via your phone or tablet, for example.
The MM phono input will delight vinyl enthusiasts and collectors, who will be able to enjoy high-quality listening from their music library by connecting their turntable directly to the SMSL AS400 amplifier.
The combination of an HDMI ARC input and a preamplified output for an active subwoofer makes it easy to set up a 2.1-channel system for a home theater setup. Resolutely versatile, the AS400 will enhance the soundtrack and action scenes of your favorite movies with the help of an active subwoofer.
1 | Display |
2 | IR receiver |
3 | Multifunction button |
4 | Balanced 4.4mm headphone output |
5 | Single-ended 6.35mm headphone jack output |
6 | Phono input |
7 | Line input |
8 | Coaxial input |
9 | Subwoofer output (preamp) |
10 | HDMI ARC input |
11 | USB-C input |
12 | Bluetooth antenna |
13 | Toslink optical input |
14 | Speaker terminal outputs |
15 | 100-240V AC power port |
Product type | Integrated amplifier |
DAC chip | CS43131 |
Amplification chip | MA5332MS |
USB interface | XMOS XU-316 |
Inputs | 1x USB-C 1x RCA line (AUX) 1x Toslink optical 1x Coaxial 1x HDMI ARC 1x MM phono Bluetooth |
Outputs | 1x Speaker terminal output 1x Line output for active subwoofer (RCA) 1x Balanced 4.4mm headphone jack output 1x Single-ended 6.35mm headphone jack output |
Supported sampole rates | USB: PCM up to 32-bit 768 kHz, MQA Toslink optical and coaxial: PCM up to 24-bit 192 kHz, DSD DoP64 |
Supported Bluetooth Codecs | SBC, AAC, aptX-HD, LDAC |
Output power (Wrms) | 165W x2 @ 4 ohm 2x 85W @ 8 ohm |
Input sensitivity | 280mV/22Kohm |
THD+N | 0.003% |
SNR | 107dB |
Channel separation | 98dB |
Bit depth | 1bit, 16-32Bit |
USB transmission | Asynchronous |
USB compatibility | Windows 7/8/8.1/10/11, Mac OSX, Linux |
Power supply | 100-240V AC |
Power consumption | 40W (Volume normal) |
Weight | 1.568kg |
Dimensions | 210.4 x 46 x 254mm |
Color | Silver |
Package | 1x SMSL AS400 integrated amplifier 1x HDMI cable 1x Remote control 1x Power cord |
Input | RCA |
Input | Optical |
Input | Phono |
Input | USB |
Input | SPDIF |
Input | Bluetooth |
Input | HDMI ARC |
Output | Jack 4.4mm |
Output | Speaker terminal |
Output | Subwoofer |
Output | Jack 6.35mm |
Color | Silver |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Infineon MA5332M |
Power (W) | 165.0 |
Remote Control | Yes |
