SMSL PA200 Stereo / Mono Amplifier
SMSL unveils its PA200, a singular amplifier somewhere between a power amplifier and an integrated amplifier. The latter is capable of operating both in stereo with volume control and in mono as a pure power amplifier, and relies on Infineon GaN FET transistors. It offers up to 2x160W under 4 Ohm power via its stereo RCA input, and up to 1x400W under 4 ohm via its mono XLR input.
By buying this product you get 44 loyalty points
Reference : 20393
449,00 €tax incl.
374,17 € tax excl.
SMSL PA200 Amplifier Class D Stereo / Mono Infineon 2x160W 4 Ohm / 1x400W 4 Ohm
Photo of SMSL PA200
SMSL
 unveils its PA200, a singular amplifier somewhere between a power amplifier and an integrated amplifier. The latter is capable of operating both in stereo with volume control and in mono as a pure power amplifier, and relies on Infineon GaN FET transistors. It offers up to 2x160W under 4 Ohm power via its stereo RCA input, and up to 1x400W under 4 ohm via its mono XLR input. Inside the PA200 are audiophile components such as a PGA2311 digital volume control chip, switch-mode power supply and gold-plated connectors. Outputs are via speaker terminals, and a remote control is available for remote operation.
SMSL PA200: A powerful amplifier
Infineon GaN FET transistors enable the PA200 to develop substantial output power, whether in stereo or mono. Indeed, the stereo RCA input offers up to 2x160W under 4 ohm power, while the XLR input offers up to 1x400W under 4 ohm power. With a THD+N of just 0.003%, the PA200 can provide the soundtrack to a beautiful space, while preserving the sound reproduction of your favorite recordings.
Stereo digital volume control
SMSL PA200: Stereo digital volume control
A Texas Instrument PGA3211 digital volume control chip controls the output volume if the RCA input is used.
Please note that volume control is only available with the stereo RCA input. If you use the mono XLR input, the PA200 will not allow you to control the output volume.
SMSL PA200: Mono XLR power amplifier
As mentioned above, when used with mono XLR, the SMSL PA200 has no volume control, and therefore functions as a pure power amplifier. This enables it to gain considerable power in a dual mono installation with two PA200 amplifiers.
XLR Mono power amplifier
SMSL PA200: An amplifier made to match the PL200 and D200
The performance and form factor of the SMSL PA200 make it ideal for use with the SMSL D200 DAC and SMSL PL200 CD player.
an amplifier designed to work with the PL200 and D200
SMSL PA200 overview
SMSL PA200 overview
1Stereo RCA input
2Mono XLR input
3Speaker terminal output
4IEC power input 100-240V
Product typeAmplifieur
Amplification componantInfineon GaN FET transistors
Inputs1x Stereo RCA input
1x Mono XLR input
Output1x Speaker terminal output
THD+N0.003%
SNR109dB
Channel separation75dB
Input sensitivityRCA stereo: 0.68Vrms/22kOhm
XLR mono: 2.1Vrms/22kOhm
Output powerStereo : 2x160Wrms @ 4 Ohm / 2x85Wrms @ 8 Ohm
Mono : 1x400Wrms @ 4 Ohm / 1x250W @ 8 Ohm
Power supply100-240V AC
Power consumption40W
Standby: < 0.5W
Dimensions220 x 45.9 x 175mm
Weight1.44kg
ColorSilver
Package1x PA200 amplifier
1x Remote control
1x Power supply cable
SMSL PA200 measurements
InputXLR
OutputSpeaker terminal
ColorGray
ColorSilver
Channel1 (Mono)
Channel2 (Stereo)
Amplifier chipTransistors
Power (W)400.0
Power (W)160.0
Remote ControlYes
SMSL unveils its PA200, a singular amplifier somewhere between a power amplifier and an integrated amplifier. The latter is capable of operating...
