TOPPING MX5 Amplifier Merus MA12070 Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Black
The Topping MX5 is a combo amplifier and headphone amplifier with integrated DAC ESS ES9018. Particularly versatile and powerful, it benefits from a Bluetooth reception thanks to a QCC3031 chip, an efficient USB XMOS XU208 interface and a complete connectivity.
By buying this product you get 25 loyalty points
Reference : 15899
259,00 €tax incl.
215,83 € tax excl.
Topping MX5
Topping MX5 Amplificateur Merus Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256
MX5
MX3
USB Chip
8 Core XMOS
SA9023A
Supported sampling rates  (USB input)
PCM 32bit 384kHz / DSD256
PCM 24bit 96kHz
Bluetooth codecs
aptX / aptX LL / aptX-HD
aptX not supported
Headphone amplifier power @ 32 Ohm
1600mW
257mW
Headphone amplifier power @ 300 Ohm
260mW
42mW
SNR (headphone amplifier)
128dB
103dB
Amplifier power @ 4 Ohm THD+N < 10%
70W
40W
SNR (amplifier)
110dB
91dB
THD+N @ 8 Ohm 20W
< 0.002%
< 0.05%
Merus MA12070 Class D amplifier
Embedding an Infineon Merus Class D amplifier chip, the MX5 is capable of delivering a power of 2x55W under 4Ω (1% THD). Moreover, it offers a beautiful precision and richness of sound.
NFCA headphone amplifier
The MX5's headphone amplifier stage is based on a specially optimized NFCA circuit that ensures very low noise and distortion. It can be used with both sensitive headphones and high-impedance headphones, while providing a faithful reproduction of the original signal.
Full connectivity & Auto On/Off
Topping's MX5 benefits from a complete range of connectors, ensuring a wide compatibility with most systems. It features optical, coaxial, USB-B, single-ended stereo RCA, balanced stereo Jack 6.35mm and even Bluetooth wireless connectivity supporting aptX / aptX-HD codecs.
In addition, the amplifier supports the automatic on/off function. When a valid signal is detected, the amplifier automatically turns on, and conversely, turns itself off when no signal is received within a defined time period. In the case of analog signals, the MX5 offers three sensitivity levels to ensure accurate detection.
Tone and gain control
The MX5 allows you to adjust the bass and treble levels from -10dB to +10dB. It can thus adapt to the specificities of each audio system and to your listening.
The Topping MX5 also features two gain levels for the amplifier and headphone amplifier sections to accommodate different input signals.
Product typeAmplifier
Headphone amplifier
Amplification typeClass D
Puce d'amplificationInfineon Merus MA12070
InputsBluetooth
1x USB-B
1x Optical
1x Coaxial
1x Single-ended stereo RCA
1x Balanced stereo Jack 6.35mm TRS
OutputsSpeaker terminals
1x Jack 6.35mm headphone output
USB interfaceXMOS XU208Headphone amplifier specifications
USB / Optical / CoaxialSingle-endedBalanced
THD+N @ 1kHz (A-Weighting)< 0.003% @ 750mW 32Ω< 0.003% @ 750mW 32Ω< 0.003% @ 750mW 32Ω
< 0.0008% @ 80mW 300Ω< 0.002% @ 80mW 300Ω< 0.002% @ 80mW 300Ω
SNR @ Max out, 1kHz, A-Weighting120dB128dB127dB
Dynamic range @ 1kHz, A-Weighting120dB128dB127dB
Frequency response20Hz-20kHz (+0.1dB/-0.3dB)
20Hz-40kHz (+0.1dB/-1.0dB)
Output level5.6Vpp @ G=L10.6Vpp @ G=L10.6Vpp @ G=L
24.6Vpp @ G=H24.6Vpp @ G=H24.6Vpp @ G=H
Noise @ A-Weighting< 2µVrms @ G=L< 2µVrms @ G=L< 2µVrms @ G=L
< 10µVrms @ G=H< 10µVrms @ G=H< 10µVrms @ G=H
Channel crosstalk @ 1kHz-93dB-93dB-93dB
Input sensitivity0dBFS @ G=L3.9Vrms @ G=L7.8Vrms @ G=L
-1dBFs @ G=H1.8Vrms @ G=H3.6Vrms @ G=H
Gain6dB(Vrms/FS) @ G=L-0.2dB @ G=L-6.1dB @ G=L
19dB (Vrms/FS) @ G=H13.6dB @ G=H7.6dB @ G=H
Output impedance< 0.2Ω
Power2x 1600mW @ 32Ω, THD+N < 0.1%
2x 1000mW @ 64Ω, THD+N < 0.1%
2x 260mW @ 300Ω, THD+N < 0.1%
Load impedance> 8Ω
Amplifier specifications
THD+N @ 1kHz (A-Weighting)< 0.005% @ 5W 4Ω< 0.005% @ 5mW 4Ω< 0.005% @ 5mW 4Ω
< 0.004% @ 5W 8Ω< 0.004% @ 5W 8Ω< 0.004% @ 5W 8Ω
SNR @ Max out, 1kHz, A-Weighting110dB110dB110dB
Dynamic range @ 1kHz, A-Weighting110dB110dB110dB
Frequency response20Hz-20kHz (+0.1dB/-0.5dB)
20Hz-40kHz (+0.1dB/-1.5dB)
Output noise42Vpp @ RL=4Ω42Vpp @ RL=4Ω42Vpp @ RL=4Ω
46Vpp @ RL=8Ω46Vpp @ RL=8Ω46Vpp @ RL=8Ω
Noise @ A-Weighting< 60µVrms @ G=L< 60µVrms @ G=L< 60µVrms @ G=L
< 90µVrms @ G=H< 90µVrms @ G=H< 90µVrms @ G=H
Channel crosstalk @ 1kHz-93dB-90dB-91dB
Input sensitivity-1.5dBFS @ G=L1.7Vrms @ G=L3.5Vrms @ G=L
-7dBFs @ G=H0.9Vrms @ G=H1.8Vrms @ G=H
Gain25.2(Vrms/FS) @ G=L19dB @ G=L13dB @ G=L
30.7dB (Vrms/FS) @ G=H24.5dB @ G=H18.5dB @ G=H
Power2x 70W @ 4Ω, THD+N < 10%
2x 55W @ 4Ω, THD+N < 1%
2x 42W @ 8Ω, THD+N < 10%
2x 35W @ 8Ω, THD+N < 1%
Load impedance4-8Ω
Dimensions174 x 144 x 45mm
Package1x Topping MX5
1x Power adapter + power cable
1x USB cable
1x Jack 6.35mm to Jack 3.5mm adapter
1x Remote control
1x Bluetooth antenna
Topping MX5 Amplificateur Merus Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Topping MX5 Amplificateur Merus Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Topping MX5 Amplificateur Merus Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256
InputJack 6.35mm
OutputJack 6.35mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)55.0
Remote ControlYes
4 reviews
Incomparable!
Acheté au départ pour un usage occasionnel durant mes vacances, j'ai découvert une solution idéale pour ne pas démarrer ma centrale nucléaire en classe A les jours Tempo Rouge EDF. Consommation 16VA à écoute normale!
Sur des enceintes pas trop difficiles dotées d'un rendement de 90dB ou plus, la restitution est de qualité même en bluetooth sur Qobuz ou bibliothèque locale. En USB c'est un peu meilleur sur les messages complexes.
Excellent rapport Q/P et puissance suffisante dans les conditions ci-dessus sans distorsion.
This review has been posted for TOPPING MX5 Amplifier Merus MA12070 Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Black
Volker R.
the Topping MX5 at PC just works super.
With ELAC BSU5 quit loud enough, no noise!
The Headphoneamp has enough power for every headphone fron 30Ohr till 600 Ohm.
The only bad thing... for every Change you need the remote control...not so funny!
Performant, complet et simple.
C'est un ampli que j'attendais avec impatience car il réunit tous les critères d'achat pour une utilisation simple et seul sans baisser la qualité de restitution ! Et topping est une valeur sure avec un bon firmware.
Je souhaitez un amplificateur qui intégre un bon dac , ici le xmos que j'aime bien (j'utilise aussi un alientek d8 et un topping dac d10).
C'est vraiment un bon choix pour un appareil complet avec plein d'entrées, un bluetooth de qualité.
La puissance est suffisante pour mes monitor audi bronze II. La restitution de la musique dématérialisée provenant d'un mini pc sous manjaro est très bonne.
Je l'ai utilisée une journée complète, il est légèrement tiède, sa coque est entièrement ajourée (attention aux liquides !).
L'ampli se mettra en veille seul au bout 1 minute d'arret du mini pc (veille du pc ou arret de la musique), c'était une condition d'achat, ce matin il s'est rallumé dès que le pc lui a renvoyé du signal (aucune manip à effectuer pour les néophytes vivant sous mon foyer).
On a le choix également à plusieurs niveaux d'affichage de l'écran et par défaut une exctinction de l'ecran au bout de 30".
il est plus cher que ces concurrents ou prédécesseurs (le mx3 que j'ai et qui sert plutot comme l'alientek d'ampli de bureau avec des mini biblio), mais ce n'est pas la même gamme.
Seul léger défaut c'est l'entrée en mode settings pas évident, se fait ampli éteint, on garde bouton rotatif appuyé et on allume par la télécommande. Un bouton menu n'aurait pas été du luxe, aussi ne pas perdre ou endommager la télécommande car pas de redondance sur l'appareil pour les fonctions et la veille.
Le bouton rotatif est de qualité, le choix est de bien sentir la rotation par clics (elle sert pour le volume et la sélection de source). J'aurai préféré un bouton plus épais.
Réglages basses aigus sans pop dans la musique, 2 préreglages sur la télécommande.
Un ampli discret , de bon design mais efficace. S'il est aussi robuste que mes autres topping il restera en place longtemps.
Gilles
Amazing
I just received the Topping MX5 and i am truly amazed, the sound is very gorgeous and punchy and the tone control makes all the difference, it has driven my Hifiman Sundaras and the HE400se with authority and without problems, tried it with USB and with BT without any sound compromise whatsoever.
The Topping MX5 is a combo amplifier and headphone amplifier with integrated DAC ESS ES9018. Particularly versatile and powerful, it benefits from...
