TOPPING PA5 II Class D Amplifier Balanced 2x100W 4 Ohm Silver
Topping's PA5 II amplifier is a compact and powerful model, adopting a totally balanced structure and an innovative Class D amplifier circuit, enabling it to develop a significant power of 2x100W under 4Ω with a low level of distortion. The excellent parameterisation carried out by the brand's engineers ensures clear, clean and deep sound reproduction, with no background noise. At 5W and 4Ω, THD+N is measured at less than 0.0004%.
Reference : 18003
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 05-06-2025.
Topping PA5 II
Topping PA5 II Class D Amplifier Balanced 2x100W 4 Ohm Silver
The PA5 II also incorporates an effective and comprehensive protection circuit, acting against overvoltage, undervoltage, short-circuit, overcurrent and overheating.
On the input side, there is a choice of single-ended stereo RCA or two 6.35mm TRS jacks for balanced input. Output is via conventional speaker terminals that accept banana plugs. There's also a 12V trigger on the rear of the unit, enabling the PA5 II to be connected to other devices for automatic on/off.
To use the 12V trigger function, it must be activated using the switch on the front of the device.
1ON-OFF / Trigger switch
2ON/OFF LED indicator
3Input switch
4Volume button
5Balanced Jack 6.35mm TRS left channel input
6Single-ended RCA left channel input
7Speaker R+ output
8Speaker L+ output
9Power input
10Balanced Jack 6.35mm TRS right channel input
11Single-ended RCA right channel input
12Trigger 12V Jack 3.5mm input
13Speaker HP output
14Speaker HP output
Product typeAmplifier
Amplification typeClass D
InputsSingle-ended stereo RCA
OutputSpeaker terminals
Trigger12V
Balanced input measurements
THD+N (@ 1kHz, A-Weighted)< 0.0004% @ 4Ω 5W
< 0.0003% @ 8Ω 5W
THD+N (@ No-Weighted, 20kBW)< 0.0015% @ 4Ω 5W
< 0.0006% @ 8Ω 5W
SNR124dB (@ max out, 1kHz, A-Weighted)
Dynamic range124dB (@ 1kHz, A-Weighted)
Frequency response20Hz - 40kHz (±0.3dB)
Output level65Vpp @ 4Ω
68Vpp @ 8Ω
Noise< 15µVrms (@ A-Weighted)
Crosstalk-106dB (@ 1kHz)
Input sensitivity2.6Vrms
Gain19.2dB
Channel balance0.1dB
Output power2x100W @ 4Ω, THD+N < 10%
2x100W @ 4Ω THD+N < 1%
2x85W @ 8Ω, THD+N < 10%
2x65W @ 8Ω, THD+N <1%
Single-ended input measurements
THD+N (@ 1kHz, A-Weighted)< 0.0005% @ 4Ω 5W
< 0.0004% @ 8Ω 5W
< 0.0006% @ 8Ω 5W
SNR121dB (@ sortie max, 1kHz, A-Weighted)
Dynamic range121dB (@ 1kHz, A-Weighted)
68Vpp @ 8Ω
Crosstalk-90dB (@ 1kHz)
Input sensitivity1.3Vrms
Gain25dB
Channel balanced0.1dB
Supply voltage38VDC 3A
Power consumption< 0.5W
Dimensions (W*D*H)129*166*41mm
Weight680g
ColorSilver
Package1* Topping PA5 II
1* Power supply
InputJack 6.35mm
Channel2 (Stereo)
Amplifier chipN/A
Power (W)125.0
Topping's PA5 II amplifier is a compact and powerful model, adopting a totally balanced structure and an innovative Class D amplifier circuit,...
