XDUOO MT-605 Tube Amplifier 12AU7 TPA3116 2x30W 4 Ohm
The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a TI TPA3116 chip, allowing to deliver a 2x30W power output under 4Ω with a high efficiency. However, the circuit also integrates a 12AU7 tube, allowing to enjoy the soft and delicate sound of such a design.
Reference : 16835
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 06-05-2025.
xDuoo MT-605
Tube Amplifier TPA3116 12AU7 2x30W 4Ω
xDuoo MT-605 Amplificateur à Tube TPA3116 12AU7 2x30W 4Ω
The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a TI TPA3116 chip, allowing to deliver a 2x30W power output under 4Ω with a high efficiency. However, the circuit also integrates a 12AU7 tube, allowing to enjoy the soft and delicate sound of such a design. The power supply stage is not to be outdone, with a filtering circuit using quality Rubycon and Nichicon capacitors, ensuring that the audio circuits receive a clean electrical signal. As for the connections, the MT-605 goes to the essentials, with stereo RCA input and speaker terminals at the output.
Product typeAmplifier
Amplification chipTI TPA3116
Tube12AU7
Input1x Stereo RCA
OutputSpeaker terminals
Output power2x 30W à 1kHz, 4Ω
THD+N0.1% @ 1kHz
SNR85dB (A-Weighted)
Crosstalk60dB
Frequency response20Hz - 40kHz
Dimensions120 x 114 x 67mm
Weight390g
Package1x MT-605
1x Power supply 24V
ColorGray
Channel2 (Stereo)
ClassTube amp
Amplifier chipTube
Amplifier chipTPA3116
Power (W)30.0
3 reviews
grand régal musical pour ce petit ampli
Déçu par l'Ayima T9, je récidive pour un autre petit ampli à tube, et là, bonne pioche ! Les avis précédents sur ce MT605 m'ont convaincu car j'avais envie de varier les plaisirs d'avec le SMSL ao300 que j'apprécie toujours autant. Une puissance inattendue pour mes enceintes colonnes, le bouton de volume est à peine tourné pour emplir mon studio.
Aération et respect du grain propre aux instruments acoustiques et même électr-on-iques. Halo sonore étagé, riche en nuances et modulations typiques du tube (que j'ai changé pou un Tung Sol vendu sur ce site, le chinois d'origine étant un peu dur et fermé par rapport à ce tube russe).
Un peu de souffle dans les enceintes en y collant les oreilles, un "ploc" surtout audible en éteignant, chauffe un peu, bouton de volume bon marché. Mais le plaisir plus palpable de l'analogue est bien là, comparé au numérique. Bref, une jolie petite surprise vous attend !
This review has been posted for XDUOO MT-605 Tube Amplifier 12AU7 TPA3116 2x30W 4 Ohm
Fantastic little amp
This is a great little amp. I love tube amps and the warm sound ...this one is a super budget hifi piece. I roll to a new tube (thanks for the tip) a Tung Sol and it just sound amazing. Great mids and highs, bass is very smooth but present. The sound is vey neutral and warm ... just fantastic
Bon ampli type lampe, sans réglages, puissant
Sonne assez bien, mais iI n'a pas la dynamique et la précision des amplis transistor, dans les basses, la rythmique.
Il lui manque les réglages basse, aigu. Il donne un son assez clair, vivant, plutôt puissant. Pour moi, sa puissance de 2*30W, équivaut environ à la puissance d'un mini ampli class D de 2*100W. Mais les basses étant moins affirmées, les mediums sont les plus sonores.
Un autre ampli lampe avec réglages, et le bluetooth en ferait un idéal par rapport à celui-ci.
The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its...
