By buying this product you get 54 loyalty points
Amplifier Streamer WiFi AirPlay DLNA Bluetooth 2x115W 4 Ohm 24bit 192kHz DSD128
The Yamaha R-N402D is a second-generation MusicCast-compatible HiFi amplifier with DAB tuner that offers great sound quality and rich, musical reproduction. It's versatile and supports a variety of sources and streaming services. It also allows you to play your audio files directly from your smartphone, PC or NAS.
The Yamaha R-N402D is both an amplifier and a network player that can access your audio files stored on your local network from a computer or NAS. It is also capable of streaming your music from many popular streaming services and web radio (via vTuner). In addition, the MusicCast app allows you to enjoy music stored on your smartphone or tablet directly via a wireless connection.
The MusicCast system uses a high-performance wireless network to stream your music unaltered. Using this protocol, you can stream your audio files directly from a smartphone, PC or NAS to your MusicCast devices. In addition, audio content from smartphones and tablets can be distributed to multiple MusicCast devices in multiple rooms.
With the R-N402D, your smartphone becomes a true audio source, thanks to the device's compatibility with Bluetooth, AirPlay and DLNA transmission protocols. It's easy to stream your music from your audio applications, radios or streaming services.
The R-N402D is equipped with the latest Bluetooth technology, making wireless use easier than ever. For example, you can stream your music from the R-N402D to a Bluetooth headphone for a private listening session, to a Bluetooth speaker or to any other compatible device.
The network player supports DAB and DAB+ technologies, digital audio broadcasting systems offering access to a wide range of radio stations with high quality sound reproduction. It also automatically finds available stations in a list and displays information such as the station name. No less than 40 DAB/DAB+ stations can be stored on the R-N402D.
The front panel of the R-N402D provides a USB-A port for connecting a USB storage device. This allows you to quickly access all your downloaded music, with the digital connection ensuring high quality playback.
Many live and classical music albums should not have any breaks between songs. Gapless mode ensures that there are no pauses between audio files, so you can play these albums the way they were intended.
Thanks to its Burr Brown 24bit DSD1791 DAC chip, the R-N402D is able to read high resolution audio streams. It is thus possible to enjoy WAV or FLAC files up to 24bit 192kHe and Apple Lossless up to 24bit 96kHz. The device also supports DSD streams up to DSD128 for an incredibly accurate reproduction.
The R-N402D has both optical and coaxial digital audio inputs. The former is designed to receive the signal from a TV and the latter from a Blu-ray player. The sound is thus managed in a completely digital way, offering a dynamic and crystal clear reproduction, whatever your sources.
The R-N402D inherits the simple yet elegant styling that Yamaha has become known for. The front panel buttons are also ergonomically designed. The brushed aluminum front panel and rotary knobs are inspired by the luxurious designs of Yamaha's high-end models.
Product type | Amplifier Streamer |
Connectivity | WiFi DLNA 1.5 AirPlay Bluetooth (SBC, AAC) DAB/DAB+ |
Inputs | WiFi Bluetooth 1x Ethernet RJ45 1x USB-A (USB Host) 1x Optical Toslink 1x Coaxial 4x Stereo RCA |
Outputs | 2x Stereo speaker terminals 1x Steroe RCA Bluetooth 1x Stereo Jack 6.35mm headphone output |
Supported file formats | MP3, WMA, MPEG4, AAC, WAV, FLAC, AIFF, ALAC, DSD |
Supported sampling rates | PCM up to 24bit 192kHz DSD up to DSD128 |
Supported streaming services | Spotify Spotify Connect Qobuz Deezer Tidal Airable (TuneIn) Napster Pandora SiriusXM |
Max output power | 2x 115W @ 4Ω, 1kHz, 0.7% THD 2x 140W @ 8Ω, 1kHz, 10% THD |
Dynamic power / channel | 125W @ 8Ω 150W @ 6Ω 165W @ 4Ω 180W @ 2Ω |
SNR | CD : 100dB FM Mono : 71dB FM Stereo : 70dB |
Consumption | 1.9W |
Dimensions | 435 x 141 x 340mm |
Weight | 7.3kg |
Input | SPDIF |
Input | Bluetooth |
Input | WiFi |
Input | RCA |
Input | Optical |
Input | RJ45 |
Input | USB |
Output | Jack 6.35mm |
Output | Speaker terminal |
Output | Bluetooth |
Output | RCA |
Color | Green |
Color | Black |
Class | N/A |
Amplifier chip | N/A |
