ADC Board Analog Digital Converter PCM1804 RCA to SPDIF 24bit 192kHz
This ADC module allows to convert an analog audio signal into digital thanks to its Burr Brown PCM1804 chip. The input is in stereo RCA and the output in coaxial or optical Toslink. The module supports PCM audio streams up to 24bit 192kHz.
Reference : 17047
39,90 €tax incl.
33,25 € tax excl.
ADC Board
Module ADC Convertisseur analogique numérique PCM1804 RCA vers SPDIF 24bit 192kHz
Product typeADC module
Input1* Stereo RCA
Outputs1* Coaxial
1* Optical Toslink
ADC chipBurr Brown PCM1804
Dynamic range112dB
SNR111dB
THD+N-102dB
Supported sampling ratesPCM up to 24bit 192kHz
Supply voltage5VDC via Jack DC 5.5/2.1mm (power adapter sold separately)
Dimensions (with connectors)68.6*50mm
OutputOptical Toslink
OutputCoaxial SPDIF
Max sampling rate192kHz
Interface chipNC
This ADC module allows to convert an analog audio signal into digital thanks to its Burr Brown PCM1804 chip. The input is in stereo RCA and the...
