Funziona molto bene, ottima alternativa all'Amanero
Works very well, great alternative to Amanero
This module is a digital interface featuring a USB-B 2.0 input, as well as two SPDIF outputs in coaxial and Toslink optical formats and a 5-pin I2S output. The interface is based on an SA9227 chip supporting PCM streams up to 32bit 384kHz, DSD256 as well as AC3 and DTS. AES/EBU is also supported.
This module requires a driver for use with Windows 7.
Product type | DIgital interface |
Inputs | 1* USB-B 2.0 |
Outputs | 1* Coaxial 1* Optical Toslink 1* I2S 5-pin |
Supported sample rates | PCM up to 32bit 384kHz Native DSD up to DSD256 AC3 DTS |
Interface chip | SA9227 |
Compatibility | Windows 7 (with driver) Windows 10 (without driver) |
Dimensions | 62*35mm |
Weight | 16g |
Input | I2S |
Input | USB |
Output | Coaxial SPDIF |
Output | Optical Toslink |
Max sampling rate | DSD256 |
Max sampling rate | 384kHz |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Raffaele V.
