This SPDIF Coaxial to SPDIF input module allows you to output in the main SPDIF Coaxial formats, AES EBU 110 Ohm, but also TTL. The whole point of SPDIF TTL is to be able to attack audio logical interfaces. The TTL format is mainly used on sound cards, ROM DriverCD and CD mechanics as well as on DSP processing cards (mini-DSP minisharc). Thanks to these Pulse isolating transformers, this digital board also provides better stability on SPDIF digital signals. (see oscilloscope photo) at the bottom of the plug).
SETTING THE Jumpers FUNCTIONS:
JP1 input selection:
Welding 1 and 2 = input J6
Welding 2 and 3 = input J1
JP2: soldering output selection J7 TTL
Desoldering : does not work
List of compatible CD management chipset :
1 | SPDIF input |
2 | SPDIF output (TTL level) |
3 | SPDIF input |
4 | 5VDC |
5 | GND |
6 | Optical Toslink output |
7 | Coaxial output (TTL level) |
8 | Coaxial output (500mV) |
9 | AES/EBU output |
Technical caratheristics | |
inputs | SPDIF coaxial et SMA + SPDIF TTL |
Outputs | AES EBU 110 Ohm, Coaxial SPDIF SMA, SPDIF TTL SMA |
Voltage DC | 5V |
Dimensions | Largeur 50mm, Longueur 70mm, Hauteur 23.5mm |
Weight | 20g |
Screws | M3 entraxe 60x40mm |
Input | SPDIF |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Max sampling rate | NC |
Mounting type | To weld |
Interface chip | NC |
