Interface USB-B to I2S / DSD / SPDIF / MQA XMOS XU316 32bit 768kHz DSD512
This USB to I2S, DSD, SPDIF and MQA interface is equipped with an XMOS XU316 USB chip and is designed for high-fidelity audio applications. The interface supports digital streams with a sampling frequency of up to 32bit 768kHz PCM, DSD512 on its I2S output and up to 192kHz PCM on the SPDIF output. Furthermore, it should be noted that MQA is supported here, thanks in particular to the presence of the XMOS XU316 chip.
Reference : 19690
75,90 €tax incl.
63,25 € tax excl.
Shipping date: 16-10-2025.
Interface USB-B XMOS XU316 : Front view
Type of productDigital interface
InputUSB-B
OutputsI2S
SPDIF
Supported sampling ratesI2S : PCM up to 32bit 768kHz / Native DSD up to DSD512
SPDIF : PCM up to 24bit 192kHz
Interface chipXMOS XU316
CompatibilityWindows 7 / 8 / 8.1 / 10 / 11 (Driver required)
Mac OS X10.6+
Linux
Android
iOS
Spacing holes22mm x 60mm
Clock jitter75pS
MQA supportYes
Dimensions35mm x 69mm (excluding connector)
Weight20g
Package1x Digital interface
1x Pin header 2x10 Pins 2.54mm
OutputI2S
OutputSPDIF
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
Download
This USB to I2S, DSD, SPDIF and MQA interface is equipped with an XMOS XU316 USB chip and is designed for high-fidelity audio...
