JST XH PH to RCA Plug Adapter Board
This small module is an adapter with a stereo RCA input on the one hand, and an XH 2.54mm and PH 2.0mm output on the other hand. It allows to adapt these connectors for easy connections.
Reference : 14784
2,90 €tax incl.
2,42 € tax excl.
Module Adaptateur connecteur JST PH XH vers RCA
Product typeXH / PH to RCA adapter board
InputStereo RCA
Outputs1x XH 2.54mm 3 pins
1x PH 2.0mm 3 pins
Dimensions50 x 23 x 2mm
Mounting holes spacing39mm
Package1x Adapter board
1x PH 2.0mm 3 pins 20cm cable
OutputXH 2.54mm
OutputPH 2.0mm
Max sampling rateNC
Interface chipNC
This small module is an adapter with a stereo RCA input on the one hand, and an XH 2.54mm and PH 2.0mm output on the other hand. It allows to adapt...
