MEZE RAI SOLO In-Ear Monitors IEM UPM Driver Ø9.2mm 16 Ohm 105dB 18Hz - 22kHz
The Rai Solo was developed by Meze to offer audiophiles in-ear headphones with a neat design and excellent performance at a low price. Ergonomic design, stainless steel shell, UPM dynamic speakers, everything is designed to deliver a rich and pure listening experience.
Reference : 14252
249,00 €tax incl.
207,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Meze Rai Solo
Meze Rai Solo Écouteurs Intra-Auriculaires IEM Haut-Parleur UPM ◄9.2mm 16Ω 105dB 18Hz - 22kHzMeze Rai Solo Écouteurs Intra-Auriculaires IEM Haut-Parleur UPM ◄9.2mm 16Ω 105dB 18Hz - 22kHz
With these IEMs, Meze moved towards a neutral but dynamic and controlled sound signature. In terms of design, the Rai Solo is based on the design of its older brother, the Rai Penta. The use of metal injection moulding for the earphone body results in a complex interior design that can be achieved in series and with high precision.
UPM Drivers
The loudspeakers used in the IEM Meze Rai Solo take advantage of UPM's design, which is much more powerful than a conventional loudspeaker. This technology reduces harmonic distortion, provides clear midrange and incredible low-frequency reproduction.
Standard driver diaphragm
In a traditional electrodynamic loudspeaker, the coil connecting wires are glued directly to the back of the thin membrane. This is the main asymmetric vibration factor.
Wire free UPM design
The new UPM loudspeaker eliminates this vibration problem: the entire diaphragm is conductive and no wires are stuck to the diaphragm. The result is an equal piston movement over the entire membrane, without disturbance due to the imbalance created by the wires.
Vibration reduction system
Stainless steel is an extremely rigid material, with low resonance and therefore limiting interference due to speaker vibration. In terms of audio performance, these characteristics contribute to the restitution of a clean, rich sound and a beautiful sound image.
Metal injection moulding body
Particularly robust, the moulded injected metal shell is totally adapted to follow you on the move. Its hand-brushed surface gives it a magnificent aesthetic.
Silver plated MMCX cable
Meze Rai Solo IEMs use a standard MMCX cable. This is detachable and therefore replaceable. The cable supplied by Meze is braided and its conductors are made of Silver Plated Copper, ensuring excellent conductivity.
Listening comfort
A comfortable wearing of the headphones is essential to enjoy the best possible listening experience. The exterior design of the Rai Solo has therefore been studied to adapt perfectly to the shape of the ear.
The Rai Solo works well with any device on the market due to their low impedance and high sensitivity. It is of course recommended to use a DAP or DAC to enjoy the full potential of these headphones.
Product typeIn-Ear monitors
DriversDynamic UPM Ø9.2mm
Diaphragm thickness9µm
Impedance16Ω
SPL105 ±3dB @ 1mW/1kHz
Frequency response18Hz - 22kHz
Distortion< 1% @ 1mW/1kHz
IEM ConnectorsMMCX
Cable length1.3m
Cable conductors materialCopper
Cable conductors platingSilver
ColorSilver
IEM shell materialStainless steel
PackageMeze Rai Solo
1x Braided MMCX to Jack 3.5mm cable 1.3m
1x EVA Transport case
3x Pairs of silicone eartips (S, M, L)
3x Pairs of double flanged eartips (S, M, L)
2x Pairs of double flanged deep insertion eartips (M, L)
ColorSilver
Impedance (Ω)16
Efficiency / Sensitivity (dB)105.0
Lowest frequency (Hz)18
Highest frequency (Hz)22000
The Rai Solo was developed by Meze to offer audiophiles in-ear headphones with a neat design and excellent performance at a low price. Ergonomic...
