VIBORG VH303G 4.4mm Jack Connector
The Viborg VH303G is a well-designed balanced stereo 4.4mm jack connector. It uses pure copper contacts featuring triple OFC copper, silver and 24k gold plating to ensure excellent conductivity and resistance to corrosion and oxidation.
Reference : 22017
15,90 €tax incl.
13,25 € tax excl.
Viborg VH303G Balanced 4.4mm Jack Connector Pure Copper OFC Copper / Silver / 24k Gold Plated Ø6.5mm
VIBORG VH303G
The Viborg VH303G is a well-designed balanced stereo 4.4mm jack connector. It uses pure copper contacts featuring triple OFC copper, silver and 24k gold plating to ensure excellent conductivity and resistance to corrosion and oxidation. It can accept conductors with a diameter up to Ø6.5mm. Assembly is done by soldering and a hex socket screw ensures perfect conductor retention inside the connector.
Technical specifications
Product typeBalanced 4.4mm jack connector
Conductor materialPure copper
PlatingOFC Copper / Silver / 24k Gold
InsulationPE
Body materialBrass
Max. cable diameterØ6.5mm
DimensionsØ9.5 x 47mm
AssemblySoldered
Packaging1x VIBORG VH303G
Max cable diameter (mm)6.5
Mounting typeTo weld
ConnecticMale
Contacts number5
Contacts Plating (Connector)Copper
VIBORG VH303G 4.4mm Jack Connector Pure Copper OFC Copper / Silver / 24K Gold Plated Ø6.5mm
The Viborg VH303G is a well-designed balanced stereo 4.4mm jack connector. It uses pure copper contacts featuring triple OFC copper, silver and 24k...
