Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
2 - 3
Mounting type
Roland S.
Dac tv
Walter V.
Great product!
Joli mais non..
Jack 6.35mm
Discover our range of 6.35mm jack connectors for the design of your analog audio cables.
