NEUTRIK NP2XX-SILENT Connector Jack 6.35mm Mono
This Neutrik NP2XX-SILENT jack connector is a 6.35mm mono connector. This 2-pole connector features gold contacts for corrosion and oxidation resistance, and a rubber body. It incorporates a built-in short circuit system to eliminate noise and POP when changing the connection of a loaded instrument such as a guitar.
Reference : 18929
13,50 €tax incl.
11,25 € tax excl.
Shipping date: 07-05-2025.
NEUTRIK NP2XX-SILENT Connector Jack 6.35mm Mono Ø7mm (Unit)
Photo of Neutrik NP2XX-SILENT connector
This Neutrik NP2XX-SILENT jack connector is a 6.35mm jack mono connector. This 2-pole connector features gold-plated contacts for corrosion and oxidation resistance, and a rubber body. It incorporates a built-in short circuit system to eliminate noise and POP when changing the connection of a loaded instrument such as a guitar. In other words, as soon as the SILENT plug is removed from the instrument, the built-in magnetic switch short-circuits the contacts.
Please note that this connector is designed for use with instruments only. Using it with an amplifier-side connection may cause the amplifier to break.
Dimensions and operation of the Neutrik NP2XX-SILENT connector
Product type6.35mm jack connector
ChannelsMono
GenreMale
TechnologySILENT-PLUG
Contact platingGold (0.2 µm Au)
Mounting typeTo weld
ELECTRICAL CHARACTERISTICS
Contact resistanceDepends on the corresponding mΩ connector
Dielectric strength0.2 kVcc
Insulation resistance> 2GΩ (initiale)
Rated current per contactDepends on mating connector A
Rated voltage<50V
MECHANICAL CHARACTERISTICS
Max. cable diameter4 to 7mm
Cable conductor cross-section1mm² / 18 AWG
Total dimensionsØ17.14 x 100mm
ColorBlack and red
Package1x 6.35mm jack connector mono Ø7mm NEUTRIK NP2XX-SILENT
Max cable diameter (mm)7.0
ConnecticMale
Contacts number2
This Neutrik NP2XX-SILENT jack connector is a 6.35mm mono connector. This 2-pole connector features gold contacts for corrosion and oxidation...
