Produit de bonne facture, attention à ne pas trop chauffer lors du soudage.
This base female Jack DC 5.1 / 2.5 mm is useful to install a power inlet in your DIY construction projects.
This is the long version of this inlet model. This longer version is suitable for thicker casings.
Supplied with washer and matching nut, installation is made simple for reliable mounting.
Its connectors are wide enough for a clean and robust welding.
They are suitable both to the PCB mounting in cable and welded installation.
This component can be used for prototyping and to repair / construction as well.
Characteristics | |
Type | Socket DC Jack female |
Inlet dimensions | External: 5.6 mm Pin: 2.5 mm Length: 8.5 mm |
Overall dimensions | Max external diameter: 10.8 Hole diameter: 7.8 mm |
PCB connectors Dimensions | 5.8 mm x 2.8 mm |
Panel Thickness max | 6 mm |
Parts supplied | |
Jack Inlet | x1 |
Bolt | x1 |
Ring | x1 |
Max cable diameter (mm) | N/A |
Mounting type | To weld |
Connectic | Female |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | None |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
