Max cable diameter (mm)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
2 - 5
Mounting type
FRANK D.
Impressionnant.
Une fois compris le systeme et en ayant pris des precautions pourque les parties en plastique ne se desolaridesent pas cette...
Bruno R.
Alain p.
top du top
Jack Plugs
We offer a very wide range of Jack connectors. Jack plugs are essential in the audio world, and are available in different formats, materials, plating, or in different ways: crimping, soldering, or clamping. Among our numerous jack connectors, discover the recognized brands such as Furutech, Elecaudio, Neotech, or 1877PHONO.
  • Jack 3.5mm
    Jack 3.5mm
    Discover our range of 3.5mm jack connectors, for the design of your HiFi analog audio cables.
  • Jack 6.35mm
    Jack 6.35mm
    Discover our range of 6.35mm jack connectors for the design of your analog audio cables.
  • Jack 2.5 mm
    Jack 2.5 mm
    Discover our range of 2.5mm jack connectors, for the design of your balanced analog audio cables.
  • Jack 4.4mm
    Jack 4.4mm
    Discover our range of 4.4mm jack connectors for the design of your balanced analog audio cables.
