SUPRAVOX 400-2000 EXC Woofer Speaker
Supravox's 400-2000 EXC is a woofer that takes the membrane of the 400-2000 and combines it with a powerful electromagnetic motor to offer the possibility of adjusting its parameters. The 400-2000 EXC is adaptable to a wide range of loudspeakers, and requires an external power supply between 9V and 15V for 3A.
By buying this product you get 135 loyalty points
Reference : 20772
1 359,00 €tax incl.
1 132,50 € tax excl.
Supravox 400-2000 EXC Woofer Speaker 120W 8 Ohm 98dB 23Hz-4000Hz Ø40.4mm
SUPRAVOX 400-2000 EXC : Front view
Supravox
's 400-2000 EXC
Product typeWoofer
Max RMS power120W
Sensitivity96 - 98 dB
Frequency response23Hz - 4kHz
Impedance8Ω
SuspensionFabric
Linear excursion10mm
Magnetic field0 - 1.6T
Diameter404mm
Bowl thickness10mm
Distance between fixing holes382mm
Enclosure hole diameter358mm
Depth of HP215mm
THIELE & SMALL PARAMETER
Diaphragm surface (Sd)855cm²
Resonance frequency (Fs)22Hz
Moving mass + air load (Mms)66g
Suspension flexibility (Cms)0.5mm/N
DC resistance (Re)6.5Ω
Equivalent volume of air in suspension (Vas)9V : 686L
12V : 686L
15V : 681L
Total quality factor (Qts)9V : 0.2982
12V : 0.2157
15V : 0.1805
Electrical quality factor (Qes)9V : 0.307
12V : 0.220
15V : 0.184
Mechanical quality factor (Qms)9V : 9.4549
12V : 9.3288
15V : 9.1932
Force factor (Bl)9V : 13.53
12V : 15.98
15V : 98.16
Supply voltage9-15V DC
Weight10.7kg
PackageSold by unit
Speaker Power (W RMS)120.0
Speaker TypeWoofer
Impedance (Ω)8
Loudspeaker diameter (mm)404
Diaphragm typeN/A
Efficiency / Sensitivity (dB)98.0
Max Linear Excursion (Xmax) (mm)10.0
Lowest frequency (Hz)23
Highest frequency (Hz)4000
SUPRAVOX 400-2000 EXC Woofer Speaker 120W 8 Ohm 98dB 23Hz-4000Hz Ø40.4mm
Supravox's 400-2000 EXC is a woofer that takes the membrane of the 400-2000 and combines it with a powerful electromagnetic motor to offer the...
