SHANLING EC ZERO T CD Player on Battery
With the EC Zero T, Shanling presents a top-of-the-range CD player featuring R2R digital/analogue conversion and amplification based on JAN6418 power tubes, offering smooth, warm sound reproduction with a typically analogue timbre.
By buying this product you get 58 loyalty points
Reference : 20774
589,00 €tax incl.
490,83 € tax excl.
    Shanling EC Zero T CD Player on Battery R2R JAN6418 Bluetooth 5.3
    Shanling EC Zero T : Front view
    Shanling EC Zero T: Exceptionally stable servo architecture
    The Shanling EC Zero T benefits from a meticulous design using an active magnetic fixing system to continuously adjust the pressure on the disc, offering exceptional stability during rotation and greatly reducing the noise caused by CD vibrations. In addition, the EC Zero T is equipped with an anti-shake system so that you can follow it everywhere without the risk of the CD jumping, plus a playback head with a gapless function.
    Shanling EC Zero T : In use
    Shanling EC Zero T: DAC R2R
    For its digital/analogue conversion stage, the EC Zero T opts for an R2R ladder resistor network, using a total of 192 resistors in a 24-bit architecture to deliver the finest possible sound reproduction. In addition, this CD player features a NOS (Non-Oversampling) and OS (Oversampling) mode, allowing you to personalise your listening experience to suit your tastes.
    Shanling EC Zero T : Signal processing diagram
    Shanling EC Zero T : JAN6418 tubes
    Shanling EC Zero T: Power tube amplification
    The EC Zero T's amplification stage is based on a pair of TPA6120 OPA coupled to JAN6418 power tubes, renowned for their compact size, low power consumption and operating stability. The use of power tubes provides warm, soft sound reproduction, but if you want a more neutral reproduction with more pronounced dynamics, a transistor amplification mode is also available.
    Shanling EC Zero T: 5500mAh battery
    To keep you on the move, the EC Zero T is equipped with a 5500mAh battery capable of providing 8 hours of uninterrupted listening when used via the 3.5mm jack output, and up to 20 hours when used via Bluetooth. It's easy to recharge using the USB-C port.
    Shanling EC Zero T : Rear panel connectors
    Shanling EC Zero T: Extensive connectivity
    Thanks to its wide choice of connectors, the EC Zero T is capable of integrating a large number of different configurations. In addition to 3.5mm and 4.4mm headphone outputs, this CD player also has 3.5mm and 4.4mm line outputs and an optical coaxial SPDIF output. In addition, the EC Zero T incorporates Bluetooth 5.3 connectivity supporting aptx Adaptive, aptx and SBC protocols. This wide choice of connections means you can use it directly with headphones or earphones, wireless or not, or integrate it into a more complex audio system and connect it directly to a power amplifier or DAC.
    Shanling EC Zero T: Robust aesthetics
    In terms of aesthetics, the EC Zero T has a retro design that includes a number of physical buttons and a volume slider, all housed in a tempered glass and CNC-machined aluminium case that guarantees unfailing durability.
    Shanling EC Zero T : components machined before assembly
    Shanling EC Zero T overview
    Shanling EC Zero T : Descriptive diagram of the various functions
    1Stop
    2Play / Pause
    3Function selector
    4Previous track
    5Next track
    6Lock button
    7Line output 4.4mm jack
    8Line output 3.5mm jack
    9SPDIF Coaxial / Optical output
    10Bluetooth receiver
    11USB-C DAC input
    12USB-C power supply port
    13Power mode switch
    Product typeLecteur CD
    Input1x USB-C DAC input
    Outputs1x Single-ended 3.5mm jack headphone output
    1x Balanced 4.4mm jack headphone output
    1x Single-ended 3.5mm jack line output
    1x Balanced 4.4mm jack line output
    1x SPDIF Coaxial / Optical output
    Bluetooth
    DACR2R 24 bit
    USB DAC supportPCM up to 32bit 768kHz
    DSD up to DSD512
    ScreenLCD 1.68"
    Digital filterNOS
    OS
    Bluetooth version5.3
    Supported Bluetooth codecsaptX Adaptive
    aptX
    SBC
    Transistor mode output powerLow gain: 57mW @ 32Ω
    High gain: 158mW @ 32Ω
    High gain (external power supply): 330mW @ 32Ω
    Tube mode output powerLow gain: 47mW @ 32Ω
    High gain (external power supply): 268mW @ 32Ω
    Total harmonic distortion more noise (THD+N)0.02%
    Dynamic range116dB
    Channel separation79dB
    Signal-to-noise ratio (SNR)115dB
    Noise (Low gain)111dB
    Frequency response20Hz-40kHz (-0.5dB)
    Output impedance4.7Ω
    Transistor mode output powerLow gain: 195mW @ 32Ω
    High gain: 551mW @ 32Ω
    High gain (external power supply): 1220mW @ 32Ω
    Tube mode output powerLow gain: 195mW @ 32Ω
    High gain (external power supply): 1087mW @ 32Ω
    Dynamic range117dB
    Channel separation103dB
    Signal-to-noise ratio (SNR)117dB
    Noise (Low gain)108dB
    Output impedance6.6Ω
    Single-ended Line output 3.5mm jack
    Transistor mode output level2.12Vrms
    Tube mode output level1.97Vrms
    Signal-to-noise ratio (SNR)116dB
    Balanced Line output 4.4mm jack
    Transistor mode output level4.2Vrms
    Tube mode output level3.94Vrms
    Signal-to-noise ratio (SNR)118dB
    Power supply5V / 2A
    Dimensions158 x 150 x 28mm
    Weight669g
    Package1x Shanling EC Zero T
    1x USB-A to USB-C cable
    SHANLING EC ZERO T CD Player on Battery R2R JAN6418 Bluetooth 5.3
    With the EC Zero T, Shanling presents a top-of-the-range CD player featuring R2R digital/analogue conversion and amplification based on JAN6418...
