Pack Audiophonics AP310-PREAMP Preamplifier + HPA-S600NCX Amplifier + XLR Cables 30cm + Trigger Cable
This Audiophonics pack includes the AP310-PREAMP preamplifier, the HPA-S600NCX stereo power amplifier, Audiophonics Wire XLR connection cables and a trigger cable. It will enable you to set up a high-performance HiFi system, capable of reproducing your music with dynamics and precision. XLR cables enable symmetrical connection, and trigger cables automate synchronized ignition of the two devices.
By buying this product you get 159 loyalty points
Reference : 20775
1 590,00 €tax incl.
1 325,00 € tax excl.
Instead of 1 753,10 €
Pack content
Pack Audiophonics AP310-PREAMP + HPA-S600NCX + Wire XLR Preamplifier + Amplifier + XLR Cables 30cm + Trigger cable
Pack Audiophonics AP310-PREAMP + HPA-S600NCX + Wire XLR cables + Trigger cables
Audiophonics AP310-PREAMP preamplifier
Audiophonics AP310-PREAMP: Balanced preamplifier
The Audiophonics AP310-PREAMP is a purely analog balanced preamplifier. Combining comfortable power with MUSES72320 volume control and full connectivity, this preamplifier is a sure bet for setting up a high-performance HiFi system.
FIND OUT MORE ABOUT THE AUDIOPHONICS AP310-PREAMP PREAMPLIer
Audiophonics HPA-S600NCX: NCore NCx500 power amplifier
Assembled in our workshops in France, the Audiophonics HPA-S600NCX stereo power amplifier, an updated and improved version of the HPA-S600NC, is now equipped with Hypex NCore NCx500 amplifier modules. These deliver twice the output impedance and distortion performance of the previous model. Like its predecessor, this amplifier is designed for power and precision, with a high energy reserve and clear, transparent sound reproduction.
Featuring a pair of Hypex NCore NCx500 modules, this Class D amplifier is extremely efficient, thanks to a high-performance HYPEX switched-mode power supply with synchronous regulation.
Like most amplifiers based on NCore architectures, frequency response remains independent of load, and electromagnetic interference is rigorously controlled, greatly limiting distortion and noise levels.
The HPA-S600NCX will therefore be particularly appreciated in all conditions where high amplification power is required, while maintaining great neutrality in signal restitution. It is equally at home in a professional studio or in a home audio system.
FIND OUT MORE ABOUT THE AUDIOPHONICS HPA-S600NCX
Audiophonics HPA-S600NCX amplifier
Audiophonics Wire XLR cables
Audiophonics Wire XLR: XLR Cables
The Audiophonics Wire range offers a selection of affordable yet high-performance cables, hand-assembled in our workshops in France. The Audiophonics Wire XLR cable features a Mogami Neglex W2549 modulation cable and Neutrik NC3MXX-B and NC3FXXB male and female XLR connectors, ensuring excellent conductivity and durability for efficient audio signal transmission.
FIND OUT MORE ABOUT AUDIOPHONICS WIRE XLR CABLES
Product typePreamplifier + power amplifier + XLR cables + trigger cables
Pack content1x Audiophonics AP310-PREAMP
1x Audiophonics HPA-S600NCX
1x XLR 30cm Audiophonics Wire cables pair
1x Jack 3.5mm trigger cable 1.8m
Audiophonics AP310-PREAMP preamplifier specifications
Inputs1x Balanced stereo female XLR
1x Single-ended stereo RCA
Outputs1x Balanced stereo male XLR
Volume range-90dB - +12dB
Gain settings0dB
+6dB
+12dB
OLED screenBrightness not adjustable
Automatic switch-off after 40 seconds
Input impedance10kΩ
Supply voltage100-240V AC
Dimensions295 x 220 x 65mm
Weight1.56kg
Case materialBrushed aluminum
Black acrylic front panel
Package1x Audiophonics AP310-PREAMP
1x Remote control
1x Power cable
Audiophonics HPA-S600NCX amplifier specifications
Product typePower amplifier
Amplification typeClass D
Number of channelsStereo (2)
Max output power (@ 1kHz, THD=1%)2x500W @ 2Ω
2x600W @ 4Ω
2x300W @ 8Ω
Inputs1x Balanced stereo XLR
OutputsSpeaker terminals
TriggerInput / Output
5-12V
THD+N0.0006%
SNR137dB
Output noise7µV
Frequency response0Hz - 70kHz @ +0/-3dB
Efficiency92%
Gain (switchable)11.5dB
19dB
24dB
28dB
Supply voltage230V / 110V (switchable with a switch at the bottom)
Case materialSandblasted aluminum
Dimensions435 x 355 x 73mm
Weight5.66kg
Package1x Audiophonics HPA-S600NCX
1x Power cable
Audiophonics Wire XLR cables specifications
Product typeXLR cables
Connectors2x Male XLR
2x Female XLR
Length30cm
Cable conductors materialOFC copper
Cable conductors section0.339mm² (22 AWG)
Cable conductors diameterØ1.9mm
Cable conductors insulation materialXLPE (cross-linked polyethylene)
Cable outer sheath materialPVC
Connectors contacts materialCopper alloy
Connectors contacts platingGold 24k
Connectors body materialPolyamide
This Audiophonics pack includes the AP310-PREAMP preamplifier, the HPA-S600NCX stereo power amplifier, Audiophonics Wire XLR connection cables and...
