JANTZEN AUDIO WAX COIL 000-8185 Waxed Taped Coil 12AWG 3.3mH
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 12AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance.
Reference : 12374
174,50 €tax incl.
145,42 € tax excl.
Jantzen Audio Wax Coil
Wax Coil Bobine Filtre Jantzen Audio
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 12AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
Product typeWaxed taped coil
MaterialsETP (Electrolytic-Tough-Pitch) C11000 / IACS Certified Copper
Inductance3.3mH +/-2%
RDC0.38Ω +/-5%
Coil height55 mm
Section12AWG
Weight2.497kg
Inductance (mh)3.3
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 12AWG ribbons hardened by a polymolecular paraffin wax. The latter...
