DAYTON AUDIO DCS165-4 6-1/2" Classic Speaker Driver Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm
This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier in class D of 100W RMS RMS or 4 Ohm makes it easy to operate.
Reference : 10155
69,90 €tax incl.
58,25 € tax excl.
Shipping date: 02-07-2025.
Grantie 5 ans
The Dayton Classic woofers are designed for 3-way construction as a low medium but can also be used as a subwoofer.
Their versatility allows them to be used both in closed and Bass Reflex
With these impressive performances and these smooth basses, they are popular in many DIY projects.
Characteristics :
  • Power: 100W RMS / 200W max
  • Nominal impedance: 4 ohms
  • Resistance DC: 3.4 ohms
  • Frequency response: 36 - 1100 Hz
  • SPL: 87.4 dB 1W / 1m
  • Coil diameter: 38.5mm
  • Nominal diameter: 16.5cm
  • Cutting Diameter: 15cm
  • Mounting depth: 8.5cm
  • 5 years warranty
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume5.66 Litres
Sealed F380 Hz
Vented Volume14.16 Litres
Vented F342 Hz
Speaker Power (W RMS)100.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)165.0
Diaphragm typeKevlar
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)36
Highest frequency (Hz)1100
4 reviews
subwoofer
un subwoofer de grande qualiter je recommande
This review has been posted for DAYTON AUDIO DCS165-4 6-1/2" Classic Speaker Driver Subwoofer Kevlar 100W 4 Ohm 87dB 36Hz - 1100Hz Ø16.5cm
Bon produit
En remplacement d’ un ancien HP de marque POWER concept
(qui fonctionne encore)
Un peu moins souple, mais très bonne réponse en puissance
(à réexaminer après rodage).
Ce HP Dayton semble à son maximum vers 100Hz dans ma configuration.
Good subwoofer
I build it in a closed box with the recommended box size. The sub cut off is 120 hz in my setup. The bass is good and tight. The metal that holds the wire terminals bends easy. So support it when pushing in the terminals.
Service client parfait
Commande livrée en 24 heures. Matériel conforme mais mal traité par le transporteur donc arrivé abimé.
Création du litige et renvoi du nouveau le jour même. Echange reçu sous 24h !
Bravo pour le service client. Au top!
Merci.
This 16.5cm subwoofer speaker has a 36hz cutoff frequency. It allows the design of small subwoofers of quality and affordable. A simple amplifier...
