Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Discover the best price-to-market ratio!
Strengths:
Subwoofer DVC 4Ω ⌀44cm 1000W RMS
This exceptional subwoofer with ultra rigid aerial chassis has powerful ceramic magnets. Its Nomex/glass fiber cone with high stiffness in honeycomb structure produces powerful bass, defined without harmful coloring. Thanks to its 2+2 coils system and its long linear elongation, this subwoofer is able to reach frequencies of 19.5Hz.
Alignment possible according to pure volume and load :
Spécifications | |
Type de haut parleur | Subwoofer |
Diamètre nominal | 42cm (18") |
Matériau membrane | Nomex Glass fiber |
Matériau aimant | ceramic ferrite |
Total diameter | 442mm |
Depth | 259mm |
power | RMS : 1000W on 4 ohm 2+2 coils MAX : 2000W |
Impedance | 4Ω |
Sensibility | 88.6dB @ 2.83V/1m |
frequency response | 19.5Hz - 500Hz |
Resistance DC (Re) | 4.4Ω |
Inductance coil (Le) | 2.22mH @ 1kHz |
Resonance frequency (Fs) | 19.5Hz |
(Qms) | 3.82 |
(Qes) | 0.62 |
(Qts) | 0.53 |
Air load (Mms) | 655g |
(Cms) | 0.1 mm/N |
Emmissive aera (Sd) | 1,219cm² |
Air volume (Vd) | 2,681.8 cm3 |
Linear maximum exurcion (Xmax) | 22mm |
Sealed Volume | 119.50 Litres |
Sealed F3 | 31 Hz |
Vented Volume | 333.86 Litres |
Vented F3 | 16 Hz |
Speaker Power (W RMS) | 1000.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 460.0 |
Diaphragm type | Composite alloy |
Diaphragm type | Glass fiber |
Efficiency / Sensitivity (dB) | 88.0 |
Max Linear Excursion (Xmax) (mm) | 22.0 |
Lowest frequency (Hz) | 19 |
Highest frequency (Hz) | 500 |
